Coolant boiling over but car not overheating
Yesterday I took out my 01 WS6, has a LQ9 6.0 liter bored out to a 408, P1SC procharger. I ran it very hard and it was hot out, when I came back home the coolant was pissing out the overflow (boiling over). The temp gauge never moved. Could this be as simple as bad coolant? My friend told me I probably blew a head gasket which I have my fingers crossed. I do have a stant cap with pressure release which is about a yr old. Should i get a new cap flush and fill and try again or should I pull the heads>? Any help would be greatly appreciated.
thanks
thanks
The cap was probably the problem. If the cap isn't a good seal, the pressure will not build up inside and raise the boiling point. Your coolant was boiling at a lower temperature than normal because of the air leak in the system.
