trying to run down a problem, quick response needed!!!
If the security system wasn't letting the car start due to cutting power to the starter, bump-starting the car wouldn't work correct? I thought I was having issues with the security system, and got stranded tonight. As a last ditch effort I popped the clutch (in reverse!!!) and the car fired right up?! Now I'm convinced it's the starter! Read more here:
https://ls1tech.com/forums/florida-m...ampa-area.html
Thank you in advance!
Scott
Scott
If it's the VATS, jump starting the car won't do any good.
