Stumped with single hi-beam light
01 V6 firebird. My right hi beam light isn't working. Both low beams are fine (aftermarket hid) and left hi beam is fine. I've swapped hi beam headlamps and the right side is still out, ruling out the actual headlamp. A voltmeter to the right hi beam plug reveals the proper voltage reading. I've checked all fuses and have found no issues. My front right turn signal build was broken but after replacing the hi beam issue persists. I'm totally stumped, does anyone have any suggestions? Appreciate it!
