Remove/Replace starter in my 2002 firehawk
Old 12-21-2013, 05:48 PM
abbers93's Avatar
Default Remove/Replace starter in my 2002 firehawk
My starter is out.
I tapped on it a few times and got it to start but I will need to replace ASAP and I want to replace it myself.
I guess my question is how difficult is it/what's the best and easiest way to go about it?
2002 Firehawk, the 5.7 V8. Thanks in advance for help!!
Old 12-21-2013, 09:42 PM
hawk584's Avatar
Buy your self one of them Haynes manuals and you'll be set, you get either download it or buy one at your local auto parts store. they usually have them on the rack
Old 12-21-2013, 11:07 PM
Kevin Lee 487's Avatar
If its the same setup as a 3rd gen, its pretty easy. Remove the solenoid first , and then the starter will have enough room to be maneuvered out.
Old 12-21-2013, 11:32 PM
jsteele90's Avatar
its two bolts to drop the starter down, then disconnect the wires from it. Make sure you disconnect the negative battery cable first.
Old 12-21-2013, 11:53 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
No need to remove the solenoid on a fourth-gen. As already mentioned, remove the two bolts (two different lengths) and then it can be wiggled out to unhook the wires.
Quick Reply: Remove/Replace starter in my 2002 firehawk
