Sequential taillights
Old 01-08-2014, 09:24 PM
TAvsGN's Avatar
Default Sequential taillights
I have been considering the Webelectric kit designed for 4th gen T/As for a little while now, and have done a search here reading the posts about it. I wanted to see if there is anyone out there that this kit and can tell me how it has been working after an extended period of time. Any problems? Some issues I have read about are one side working slower than that other and things like that. I did see a video awhile back where it looked like the signals were going way too fast, but I understand that can be controlled by the flasher? I guess the reason I haven't pulled the trigger is having to cut into the wiring and I wanted to see if it was going to be worth it.
Old 01-08-2014, 09:28 PM
Carguy8888's Avatar
In for info too.
Old 01-09-2014, 11:43 AM
_JB_'s Avatar
I've had mine since about 2005 without any issues. You can't control the rate of sequence, but you can adjust the time between flashes using a different flasher or an adjustable flasher.
Old 01-10-2014, 02:12 PM
Delfygo's Avatar
I put mine in this past summer and I Hate wiring anything but it wasn't to bad. How ever I had one side module was shorted when installed so I had to pull it and send back. They were pretty quick about getting it back no charge, must have been a fluk thing. What's nice is they are made right here in the good old USA in FLA. not in some sweat shop overseas. Only thing I would recommend would be to use crimp style connectors with the heat shrink for a better and safer connection. I recommend
Old 02-19-2014, 10:02 PM
9502's Avatar
love to know where they can be purchased..
Old 02-19-2014, 10:30 PM
Carguy8888's Avatar
I googled and found it. Youtube has a few vids under the same search. The look a bit too fast, the may look beter live.
http://www.webelectricproducts.com/
Old 02-21-2014, 12:29 PM
Delfygo's Avatar
Old 02-21-2014, 04:56 PM
Carguy8888's Avatar
Originally Posted by Delfygo
Could you post a vid for me/us? Your hood is awesome.
Old 02-22-2014, 09:56 AM
Delfygo's Avatar
If your looking for a video on lights car is away for at least another month, sorry if your looking for pics of hood look in my profile there are pics there in a album.
Thanks
Old 02-23-2014, 06:33 PM
Carguy8888's Avatar
I found your profile after, it loks great. My car is away too.
Old 02-23-2014, 06:42 PM
Snake_Skinner's Avatar
sub'd
Can you use LED's with this kit somehow?
Old 02-23-2014, 07:11 PM
TAvsGN's Avatar
Not sure, but I think I remember something on the website about using LEDs.
Old 02-24-2014, 12:21 AM
_JB_'s Avatar
Originally Posted by Snake_Skinner
sub'd
Yes you can. The flasher is what causes LEDs to not work correctly. I would advise against LEDs in the taillights for two reasons:
1. Unless you buy Triton LEDs no other LED will be as bright as stock. Tritons are about $100/pair. There is a reason why you NEVER see anyone post LED lights in the daylight. Even the Triton red LEDs only produce 210 lumens, so I'm not sure if that's up to par or not.
2. Taillights will have hot spots. Not sure if Triton LEDs produce hot spots.
More info: http://www.vleds.com/v3-triton.html
Old 02-24-2014, 04:50 AM
Latigo's Avatar
So do the brakes illuminate sequentially when you are just going to stop? If so, that kind of a bummer, but not a deal breaker.
My main concern is the farthest bulb on the outside since it's dimmer than the others. Is there a way to get all the lights to be equally bright?
Old 02-24-2014, 07:49 AM
TAvsGN's Avatar
Yes, according to the website, the brakes can give a sequential burst before staying on, but can modify it by the wiring to do the turn signal function only. As far as the outer light being dimmer, I believe they took care of that by supplying a 921 bulb to replace the 194 in the outer socket.
Old 02-24-2014, 10:10 AM
Delfygo's Avatar
This is true, one burst and stay on (very Cool). Outer bulb is replaced and is wired to flash with the kit.
In my opinion this is a quality American made product and I'm very please with however as mentioned above I would use a crimp style connector with heat shrink that is already on connector in stead of the supplied connectors. 3M also make's a similar connector that is used in the kit that is filled with dielectric grease and is to be far better than the cheapies.
Make sure units are mounted upright securely before testing as I think they have a mercury switch in them. I had one short because I was in a hurry(sent back and was repaired no charge) but they warn against it it directions. I just drilled some holes in the taillight wing nuts and zip tied them secure and ran some duct tape over for protection.
Old 02-25-2014, 02:17 AM
Latigo's Avatar
Oh ok I see that now --looks like they call it smart sequence.
Well... looks like I'm getting sequential turn signals!
Old 03-05-2014, 09:50 AM
MasterV8's Avatar
Just installed Triton v3s in all rear lights(brakes, signals & reverse) and they're very bright even in daylight compared to stock & no hotspots!
I have their switchbacks as well but haven't had a chance to install them yet.
Old 03-05-2014, 09:56 AM
_JB_'s Avatar
Awesome great to hear! Any pics with stock on one side and Triton in the other? I have some amber ones on backorder, I want to use them for the front DRLs.
Old 03-05-2014, 10:21 AM
MasterV8's Avatar
Unfortunately not! I knew I should have.
I also had to use the fuses in the relays for the brake lights as well, because they were causing some of the bulbs in the 3rd brake light to stay dim with no other lights on.
https://ls1tech.com/forums/appearanc...installed.html
Quick Reply: Sequential taillights
