Fans not coming on?
Fans not coming on?
I just picked up a 98 TA and I haven't really driven it till today and I noticed the temp slowly gets close to 210 when just sitting in park. I checked the fans and they don't come on unless I have the AC on?
I'm assuming your talking about the plastic cover in front of the condenser? & what does that have to do with the fans coming on when the temp is higher than it's suppose to be?
teh PuRpL3z
If your fans don't come on, you might want to make sure the fuse for them isn't blown.
OP -
Also, though I don't think this is the issue, check your cooling fan relays (plural) for proper functionality.
If 210 degrees makes you uncomfortable, you are not alone.
Solutions? Get a SLP manual fan switch (to turn the fans ON when YOU want them ON), or get a tuner to change the parameters within the PCM.
(My car never exceeds 185 degrees.)
I have this same problem. Not entirely sure if mine turns on in my 95 V6. At movement (30+mph), I stick to just above the 1/4 mark. But at a standstill it will hit the center line and start to move just past it. To be honest, I don't know if its the fans, the coolant isn't getting around (150k car) or the gauges are acting funny because my fuel level jumps around.
as for the OP, you could do a coolant flush, just to make sure you don't have a bunch of sludge built up in your cooling system. Anything up to 210 is normal, if it starts inching over 210 (just a needle mark or 2) then flush it.
flush the cooling system and do a new thermostat, if you are seeing drop back to the 1/4 mark after getting near 200 then and this happens when driving above 30-40 for an amount of time that is a sign of either no thermostat or a stuck open one. Also wouldn't be surprised at that mileage if your getting about to need a water pump on it.
the thermostat comment was directed @ delrio_bird not you, plan for a good flush done over the course of several days if you find it to be extremely gunked up tho, after 3 weeks I'm still getting specks of the black inards of the hoses when I drain the system, so I just put on new upper and lower radiator hoses this past weekend and will be doing new heater core hoses before putting fresh anti-freeze in.
