2000 Trans am Exhaust replacement
Old 04-28-2014, 09:49 AM
TimL865's Avatar
Default 2000 Trans am Exhaust replacement
Hi, Im new here and have a question about exhaust. My 2000 TA has 81k miles and i need to replace the muffler and tail pipes. The previous owner replaced it with a hooker muffler and tail pipes. Any recomendations as to what is good without blowing out my eardrums? Its a daily driver. Thanks!
Old 04-28-2014, 11:27 AM
z-maro's Avatar
The hooker is a pretty quiet exhaust on these, other than that you could check out magnaflow.
Old 04-28-2014, 12:45 PM
BigBird 02TA's Avatar
I have a flow master exhaust on mine and I think it sounds really nice, it has a nice rumble to it without being excessively loud.
Old 04-28-2014, 01:12 PM
hardbones's Avatar
Location: Illinois, as close to "Normal" as I can get...
Magnaflow cat back is good for a daily driver, not to loud but still sounds good when you get the rpm's up
Old 04-28-2014, 08:12 PM
TimL865's Avatar
Well my cats are shot, but as I am moving to California from NY i need to keep the CA emissions intact So i need to get the cats and everything back.. Where do you guys go for exhaust? Summit? Thanks for the input
Old 04-28-2014, 11:24 PM
M4N14C's Avatar
Summit, maryland speed, speed inc, ws6 store are all good. Call em up and see if they got a sale going on.
Have you thought about getting cutouts? Good choice for a DD.
Old 04-29-2014, 06:30 PM
Daniel Richards's Avatar
man, gotta be honest, if the Hooker Cat-back is to loud for you then you might as well go back to stock, it's pretty mild most of the time unless you just happen to be in the "drone zone" for the setup or are constantly revving it way up.
I have it myself, one thing I would suggest is get under there and inspect it to make sure it was done right, if any of the pipes are pushing up against ANY section of the under body that can create a reverb through the whole car making it sound louder then it is, I had this issue because I couldn't get the passenger side exit pipe to go all the way and so it was against the underbody for a few days and got WAY quieter after fixing the issue causing it..
Quick Reply: 2000 Trans am Exhaust replacement
