Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
Old 03-19-2007, 05:13 AM
  #201
Art Vandaley's Avatar
morning bump, don't want to have a winking bird help guys..
Old 03-19-2007, 09:50 AM
  #202
tomustang's Avatar
Originally Posted by deanasdork
I'm sorry that I have not read the sticky, i am kinda frustrated and just want a quick answer.
tonight my friend and I deleted my air on my 99 trans am. I went out for a test drive and turned the lights on.. and wtf... the passenger side came up and the driver side did not. i am sure that my friend and i did not do anything but delete the air system. we didn't touch anything near there. when i turn the lights on... i hear the passenger motor but the driver side.. nothing.. i don't hear anything.. the light is turning on.. just not poping up. what should i look for? everything seems to be connected...
is there anyone in Orlando that can help me out? I don't want to take it to the stealership... thanks everyone.
If you have a multimeter or volt tester you can start by checking to see if there is any power going to the motor
Old 03-27-2007, 06:23 PM
  #203
Levman74's Avatar
i just keep having issues with mine, the motors would grind up and down, replaced them with brass gears, tightened up the housings, then they broke the stops, so i put metal in place of them. Now they get super-tense when they contact the stops, and now the right one is grinding again. sometimes they alternate going up or down left or right, im working out a deal to get the conversion headlights that don't pop-up, totally eliminate this problem.
Old 04-01-2007, 08:13 PM
  #204
TAGIRL99's Avatar
I'm thinking about gettin the stationary headlights and avoiding the problem all together, they're sweet looking but a little on the expensive side
Old 04-04-2007, 11:26 PM
  #205
HGK
HGK's Avatar
I need two new actuator relays to get my popup lights to work,anyone that knows were i can get them and what they cost???
They are for a 82 Firebird,did GM use the same kind of relays on the Fiero???
Old 04-25-2007, 09:02 PM
  #206
nytmare1's Avatar
Just wanted to say thanks for all the previous headlight questions and answers.
Yesterday morning, my driver side headlight wouldn't flip up. The lights functioned, but no movement. I've had the chattering gear problem, so I knew my problem wasn't related to that.
I checked my headlamp control module and it appears to be fine with no corrosion. There was also an ample amount of juice leaving the module and arriving at the headlamp motor. I checked all the wires to be sure there wasn't a kink or a bare spot grounding it out. Nada. I then checked the little plastic tab that the metal arm rests up against when the headlamp is closed. There was a noticeable groove worn in the tab. I considered replacing it with the hose fix I read about, but then thought... "why don't I just flip the damn thing over?" I did, and it works fine again. So, if you still have the plastic tab, simply flip the damn thing over and you'll likely be good. I did the passenger side too just in case since it had a good groove in it too.
Thanks again for the assistance,
Marc
Old 04-29-2007, 07:35 PM
  #207
1 BAD BIRD's Avatar
Default For those who replaced their headlight gears I have a question!!
I replaced mine about 3 months ago with the brass ones. Well I noticed one headlight was acting weird...slower and all. Well turns out my cover was working its way loose. My question is. What apoxy do you all use that will keep this thing on? I forget what I used but it was a two part kit. Anyone have any suggestions. The sucky thing is I took it up to get inspected for the year and they call me and said my headlight wasn't coming up duh so gotta get it fixed ASAP
Thanks guys.
BOb s
Old 04-29-2007, 09:08 PM
  #208
DrkPhx's Avatar
What cover are you referring to? You should of saved yourself the aggravation and just bought a new GM motor. I bought new one on Ebay for 87$ shipped.
Old 04-30-2007, 12:35 AM
  #209
OMGWTFBODY's Avatar
85 shipped for the two brass gears.
Old 04-30-2007, 01:31 AM
  #210
Jeresous's Avatar
I'd rather buy a brass gear then a new GM motor. A new gear in an old motor is prob more reliable then a new motor, the plastic gears they use suck.
Old 04-30-2007, 02:17 AM
  #211
blackpontiac's Avatar
Yeah, good problem. I replaced my left one with a brass one... same cover problem. Tried a few different epoxies. the regular 2 part, and the plastic 2 part. neither lasted long. the plastic stuff did better, although i could have done it a little better.
haha, I settled with a peice of wood jammed between the cover and that area of frame that makes it a PITA to take off the motor... its outlasted everything... ghetto, but works! Mines not a show car.
Old 05-10-2007, 05:52 PM
  #212
Charlie Hustle's Avatar
I havent been able to find anyone else on here with the same problem. Every time I turn the headlights on, they will pop up 100% of the time. The problem is that they only go down maybe one out of every 50 trys, and Im not exagerating the number. I usually have to manualy put them down at night, so I wont have to deal with it in the daytime the next day. Now heres my question, if they gears were stripped, would the headlights still go up every single time? Also, if the gears were stripped, would I be able to manualy put the lights down? Just FYI Ive never had the loud grinding noise issue. Any suggestions? Im at the point where Im about to buy 2 new motors from ebay.
Old 05-15-2007, 03:13 PM
  #213
kliuzzo's Avatar
im having the same problem...my pass side goes up and down whenever it feels like....it usually goes down by itself and i usually put the pass side up manually..sometimes the pass. side comes down half way...no grinding at all...there is power going to it so i have no idea what the problem is..
Old 05-27-2007, 06:27 PM
  #214
My94TransAm's Avatar
I have a question about rotating the raise/lower manual ****. Do you just rotate the round **** on top 180 degrees, or do make that **** rotate the whole gear assymbly 180 degrees?
Old 05-27-2007, 09:02 PM
  #215
Danny2tek's Avatar
You rotate the **** until you see gear do a 180 rotation.
Old 06-11-2007, 07:22 AM
  #216
JayBirdWs6's Avatar
Originally Posted by madprops0
Everytime i click the lock or unlock on my clicker the headlights open then close then once closed the left makes a jack hammering noise, i read the sticky on the head lights saying to rotate the gears but why would the lights open when hitting my keypad?
Mine just started doing that crap. GOD DAM! (sorry god) that grinding noise is loud and embrassing. Went to a car show this past sunday and I didnt want to hit the lock button on the remote because of it so for the first time I locked them the old fashion way it felt weird. Whats a new motor cost?
Wow! Yearone has them for 166.00. Is that price alittle high?
Old 06-14-2007, 08:17 PM
  #217
JayBirdWs6's Avatar
Got a ACdelco GM motor brand new off ebay for 122.00 put it in this evening and were back in business. Now my drivers side comes up just a hair slower then my passenger side now.
Old 07-04-2007, 10:35 AM
  #218
UNmolestedTA's Avatar
Default Headlights...I read the Sticky!!!
Thanks for making a sticky about this subject because I would have taken my car to the dealership and spent way too much money! Is it really important to use the epoxy to reseal the motor and what will happen if I do not use the epoxy?
Thanks,
Mike
Old 07-04-2007, 10:41 AM
  #219
Pontiacerator
RevGTO's Avatar
The housing will come apart. You really have to slather the epoxy on thick.
Old 07-04-2007, 10:42 AM
  #220
'Trust''s Avatar
If you dont use epoxy (sometimes it wont even hold) the housing will open up and the gear will pop out and it can get stripped again. The best way is to use tiny screws to hold the housing together, it NEEDS to be sealed one way or the other.
Quick Reply: Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
