Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
So what should i do when one of my headlamps goes up when the other goes down and visa versa? My passenger headlamp is in synch with the switch. The driver side is opposite. What does this mean?
The following users liked this post:
Motion.Picture (10-25-2020)
Turn off the headlights and manually lower the one that is up. I believe that should get them back in sync. Have you done anything to the headlights? If that doesn't work I say turn on the headlights disengage the arm, raise the headlight and reattach the arm.
Originally Posted by Kyle C
I don't have the ratcheting noise but the drivers side light doesn't always come up. If I turn the lights off and back on a couple of time it usually comes up. It happens mostly on cold mornings. Any ideas?
Same problem... my drivers side would flap up and down everytime i locked my car, and made a grinding sound when it finally closed... so we just replaced the light motor and it works fine now. Hopefully it doesnt happen again.
Originally Posted by SpeedSin
Wouldnt use WD40, its water-based (promotes rusting). I would use some sort of silicone based lubricant. Or a maching oil. Later...
The WD stands for "Water Displacement".
Learn something new everyday don't you?
Originally Posted by blu98ta
My passenger side headlight bounces when I drive. I have had friends in front of me that say they can see it bouncing. Anyone know whats causing that?
#34
more KUDO's for the temp fix! I had been running aroung with both "eyes" open for better than 6 month (1. I'm lazy and hadn't ordered the brass gears 2. I work for uncle sugar and money for the gears is tight much less new motors, espicially with gas prices now) I just pulled the 2 15a fuses in the engine bay for the headlight motors while the lights were on and they stayed up
anyway, I just wanted to post up another sucess story and a warning .. I used a hammer and punch to "fix" the loose motor body it was talking about and bending the little tabs down. on the 4th tab I guess I got a little over zelous but it punches right through the PLASTIC of the upper gear area . I don't think I have to worry about that side loosening up again dropped a spot of clear titanuim silicon on the hole left by the punch and works like a champ. My baby can "sleep" at night now
next problems to tackle:
power antenna grinding, no all the way up or down (pulled power connector from it in up position too)
monsoon radio display going nuts and unable to read most of the time ... clears up sometimes though. (Fixed this once by resoldering the connection to the main board inside the head unit. it gets cold solder joints there and erounous signals to the microchip freaks it out. time to fix again I guess)
rattleing noise in drivers side door with the window down when closing the door. windows works good (up and down) just bangs pretty loud when shutting with the window down even just a little bit.
OH yea ... she smokes like George Burns under heavy throttle still runs great but fouls plugs every 20K or so. installed the AMW catch can (very nice piece of work) pressure check and leak down test checked out good (within +/-10 of each other all cylinders) but still a smoker
#35
i've had the same problem they said the motor in the light was broken or somethin like that. Since this is talkin about head lights and everything... does anybody have halogen fog lights? i wanted to know if you guys liked the look they give
#36
Well about a few months ago i did the brass gear mod to my drivers side light because it was grinding away everytime i locked my door or turned off my lights. Well just recently now the drivers side light does not go up. The light turns on because you can see it. But the light does not come up like its supposed to. Im assuming the motor as just gone bad. I don't have the money to buy a rebuilt one but is there a way i can lift the light up with the **** then take out the fuse so that both headlights can stay up?
-Joel
-Joel
#37
-Joel
-Joel
#38
#40
ok..im havin an issue with my passengerside headlamp assembly...wont come up..light is workin but motor is not. fuse is good and there is power at the connector to the motor. the connector was corroded but after some clean up still did not work. light itself will come on though which would lead me to beleive the motor is shot. anything else i can do to confirm this??
