Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
#1042
help please
I have read through as much as I can and I tried replacing the motor checked the fuses and swapped the headlight module out and I still can not get the drivers side light to come up and down its lit but doesn't move. Does any one know what I should look for now.
#1044
Yeah I checked the connection w a volt meter and had my dad turn the lights on and off and never saw any power to the end of the connector that you plug the motor into. I think it was 5 prongs
#1045
Don't quote me, but I think the 5 wires are positive to high beam, low beam and ground for the bulbs then the other 2 are positive and negative for the motor that gets switched depending on which way the motor should turn.
It sounds like a more in-depth electrical problem that I can handle cuz all my motors and stuff are long gone. I'll try though.
So you say the left motor works, but not the right?
Try checking the right side fuse with a multimeter or swap the left and right side fuse just to make sure a blown fuse not the problem. sometimes they can blow, but look fine.
If that's not it, pull both fuses and see if power is going to both fuse sockets. They might be hot all the time or maybe just right after turning on the lights. If the right side fuse sockets get no power (and the left one does) you'll need to look under the fuse box because they both get power from the same wire.
If both fuse sockets do get power then I think it's something with the headlight brain by the fuse boxes. Are those 2 big plugs all clean or corroded? Did you say you swapped it already?
I know you said there was no power going to the motor, but make sure the motor is not bound up. Turn the manual **** until the motor is moving freely. This is just to cover all bases.
#1046
Both hdl door fuses have their own orange wire coming from it. I bet that those are the same 2 orange wires going to the 5 pin connector on the headlight brain module.
See if the fuses have power, if so, then see if those 2 wires I mentioned above also have power to them at the brain box.
Yep, the right side door fuse goes to the orange wire on the end of the 5 pin connector. The left side to the other orange wire. They should both be hot at all times.
#1047
If it is the plug, it is very easy to replace, and I've posted the AC Delco part numbers for both plug ends in another post. I think it's even in THIS sticky that I posted it. I did not clip off the extremely long wiring that came with the new plugs as it gives me a boat load of room to deal with the plugs in the future. A bit of wire loom and it looks all nice again.
#1048
I cannot find one thread about replacing the headlight motor. Do I have to take apart the whole headlight asembly? This is such a PITA! How do u people with big arms and hands fit a ******* wrench under the headlights to the bolts on the motor! No wonder Pontiac got canned.
#1052
Ok so I bought a new motor. After I took the other one off I noticed I slight kncking sound comming from the other motor. Not like a stripped gear just a little knock that's constant untill I unhook the battery. The I realized that the privious owner did some Jerry rigging. The connectors on the actual headlight on the pass. Side face like this, - -
the ones on the driverside are l l
so someone decided to splice in two different connectors and a home made ground. It looks like the old connectors had corrosion so they probably didn't want to fix it the right way. So should I just resplice and put new plugs on for the headlamps?
#1055
On my 2002 WS6, the passenger headlight is dimmed to the point of being barely lit. The odd thing is, when i switch to high beams, it turns off completley.
Also, theres a lot of flickering so alternator causing the problem or just a part of it?
#1056
The quickest way to swap the motor is to remove the 2 bolts than the headlight pivot on. You need an torx head socket and a long extension. Then a 10mm ratching wrench will make quick work of the motor bolts. The headlight cover stays in place, but the plastic shroud has to come off.
#1057
The headlight bulb wires are seperate from the motors. Their wires go thriough the headlight switch. Are the drivers side lights brighter?
I'd check the plugs that go on the back of the bulbs. They get corroded often. If they are, then the easeist fix is to cut the connector off and crimp on some insulated female spade connectors.
#1058
I dont know if this has been answered before, I read through alot of it but may have missed it. About 2 months ago I put on the mods in my sig and disconnected my battery. When I had everything put back together, I went for a drive that night and went to turn on the headlights only to find out the passenger side came up but not the driver side. So I manually ran the light up, then shut the lights back off and it worked fine. I guess it reset it or something.
Now, last week I diconnected my again to clean up the tray under the coolant tank since its rusting. Got everything put back together, went to turn the lights on and now the driverside comes up, but the pass dont. So I tried running it up manually like I did the ds thinking it would reset it too. Nope, doesnt do anything. It turns on but wont move up or down. So I just left it up and trying to figure out what the hell is goin on with them.
I never had a prob with my lights before, It only happens when I unhook the battery that I have probs with them going up and down.
Any suggestoins?
Any suggestoins?
