Doors lock, but dont unlock? or vise versa?....FIX here
Old 10-12-2015, 10:47 PM
rimfire27's Avatar
Default Doors lock, but dont unlock? or vise versa?....FIX here
My Doors unlocked but didn't lock and I noticed quite a few of unanswered threads so heres what I did with mine
I took out my BCM and noticed one of the copper tracks had a tiny, minor burn in it preventing continuity under the relays ,(screw buying a new BCM and messing with keys and VATS)...SO,I grabbed a small piece of wire and soldered the two joints together on the circuit board with it and BAM! it worked flawlessly! I now get to enjoy both my locks again, and yes, yes i already soldered the notorious "t" joints a long time ago.Only took an after pic
if this is in the wrong area in the forum I apologize just trying to save some of us money
Old 10-15-2015, 11:57 AM
JohnnyBs98WS6Rag's Avatar
Thanks for sharing, love it when a quick, cheap fix saves a ton of $$.
My driver's door switch just stopped un-locking the other day, passenger side switch and remote works OK, so I think my problem is in the door switch or the wiring to it.
Old 10-24-2015, 10:53 PM
rimfire27's Avatar
Its either the actuator or the actual wire wire in the BCM that manages the drivers side, if you dont have an aftermarket alarm with a separate relay harness my money would be on the actuator
Quick Reply: Doors lock, but dont unlock? or vise versa?....FIX here
