Alternator help
Alternator help
Alternator wire from battery melted... all the way along the wire. When I replace it will putting an inline fuse help, or should I use a different gauge wire.
That's MISTER MODERATOR
63 amp? What year is this Firebird?
Usually a melted wire indicates a short or severely heavy load.
When an alternator is bad, it stops putting out power, not burn up cables.
https://ls1tech.com/forums/generatio...g-threads.html
1980.
So anyways. I ran 8ga wire to the alternator with only one join in it, and two additional wires for the other two that were spliced into my old alternator wire . So now the distributor, alternator, and the third red wire have their own decdicated power source now
Usually when this happens, there was a short on the other end of the wire. All the splicing you do won't tell you where the short was.
If it was in fact a short, the fuse will blow when you apply power.
Before you start replacing and adding parts, first confirm what caused the problem.
Runs like a champ now, pretty sure it's cuz the guy had everything running on one wire.
Found an engine harness on ecklers though. Gunna buy that when I have some dough.
