Suspension after hit
So my chicken took a hit the other day (guardrail) to the driver side front fender. The fender fiberglass is cracked and splintered so it's trashed. So we jacked it up and took off what we could ..suspension (shock and coil) is ok no damage (thank god) and the hub seems to be no damage. The main problem we have is that the the front left wheel now has negative chamber..not a ton but enough you will notice..my question is with the main suspension ok what are the odds it is the upper control arm that got out of whack? It was a low speed impact (maybe 20 mph tops) airbags didn't deploy so I have a hard time it would screw with the knuckle. There was a small dent in the actual wheel weld. anyhelp would be greatly appreciated. Will try to get pics up
we did ..everything looks good the only thing we really noticed is up by the upper control arm is a smaller gap between the knuckle and shock and coil of the suspension. but everything looks good
