upper combustion cleaning - V6
Old 02-16-2016, 02:39 PM
bleepster's Avatar
Default upper combustion cleaning - V6
looking to clean my upper cylinders this spring - utilizing something similar to seafoam or berrymans.
i know that using the break booster vacuum line aint the best because only the rear cylinders get the treatment.
others recommend using the PCV vacuum hose. the 2002 V6 has an internal PCV valve, no hose.
what other method can i use to get the product into all cylinders?
what about putting it in a spray bottle and shooting it down throttle body?
thoughts?
Old 02-16-2016, 04:17 PM
bgw70's Avatar
If you must, read this first...
https://ls1tech.com/forums/general-m...-your-car.html
Old 02-16-2016, 08:43 PM
bleepster's Avatar
Thanks. Read that. That points to still using the PCV valve. As mentioned the PVC on the V6 is internal. No hoses.
Any other ideas out there?
Old 02-16-2016, 10:33 PM
WarShrike's Avatar
There's a top end cleaner system that attaches to the fuel rail via the schrader valve and the car will run on it until it is emptied. This cleans the injectors as well as breaks up the carbon on the back of the intake valves, etc.
Old 02-17-2016, 04:03 AM
bgw70's Avatar
I cleaned it this way...
https://ls1tech.com/forums/pontiac-f...-cleaning.html
Old 02-17-2016, 07:14 AM
bleepster's Avatar
^^ thanks - i'll check into that appreciate the comments
Quick Reply: upper combustion cleaning - V6
