Autotrix wiring question
Hey everyone. For those that have installed the passenger window fix from autotrix, where did you splice in the wires to the connector in the window control panel? The instructions say to cut the brown wire and dark blue wire, but don't say which wire to splice into which. I'm thinking the red wire gets spliced to the dark blue wire, and the black wire gets spliced to the brown wire. Anyone know for sure?
Hey John,
I don't see a PM in my inbox, but I ended up getting it all wired in. I remembered that a wiring diagram was printed out with the instructions, so once I actually took a look at that, it was pretty easy to figure out. Putting the PCM back in was a nightmare, but that's just a complaint. Anyway, thanks for the info and the offer to help. It's much appreciated.
- Brian
- Brian
Haha they're definitely cracked (on the panel itself, a little more than halfway back, about two inches starting from the window and coming into the interior), but I didn't fix them. I'm now guessing this is a typical problem. Do you know a good fix for it, short of replacing the entire panel?
