Help! Gauge Cluster Wiring Issue and VATS!
I have a 2002 formula. Yesterday the security system won't let me start the car. It happened many times before, so I decided to use the resistor method to bypass the VATS.
I took off the bottom dash covers, disconnected the trunk release button. Then I tried to turn on the key, and the RPM and fuel gauges start to twitch, no oil level read, and battery level is very low. I tried to put turn signals and hazard on but they won't come on. Plus the power window is very slow. If I touched some wires that made them loose, I would like to know where are they located.
Double check the battery. The volt gauge might be reading correctly. Low voltage can cause weird things to happen. Battery might have a bad cell.
Check voltage
Put on battery charger or jump start to see if it changes
Good luck
Check voltage
Good luck
Even if the VATS is engaged, the lights still should work. I second checking the battery.
