How to access bulb by headlight switch?
Old 12-12-2016, 09:08 PM
Jim Cuff's Avatar
Default How to access bulb by headlight switch?
I am trying to swap the bulb behind the head light switch.
I pulled the dash bezel and I can see the light bulb and the plate but it seems glued in place and the harness is in a spot hard to reach to disconnect.
I pulled the lower kick panel too. Has to be a simpler way to swap?
Old 12-13-2016, 08:50 AM
Jim Cuff's Avatar
How do I gain acccess to the switch and bulb? How do I remove the bezel from fog switch without disconnecting plugs?
Old 12-13-2016, 11:53 AM
94_LT1_TransAm's Avatar
That switch will pop out if your careful. There is two round cylinder clips on the right side that pop into the dash. You may take a screwdriver to it to pop it loose. [Image was pulled from ebay]
Quick Reply: How to access bulb by headlight switch?
