Flat or low cowl hood
Old 01-28-2017, 10:20 AM
Knick's Avatar
Default Flat or low cowl hood
Hey guys
I have a firehawk with Joe Van Overbeek 5"cowl hood. I need a lower hood so I can drive it on the street. The cowl has been cut so I need one that goes back to the windshield and it has to be a lift off. I thought I would check in here to get recommendations for a quality hood.
Thank you!
Old 01-29-2017, 08:26 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
There isn't a flat hood available unless you do what I did. I bought a VFN extended nose hood for their fiberglass front end. It is too large on every edge for a stock nose, but trimming it down on each side worked like a charm.
Old 01-29-2017, 08:28 AM
'Bird Director
y2k_ta's Avatar
Old 01-29-2017, 09:13 AM
Knick's Avatar
I cant tell in your pic, but does the back of the hood go all the way to the windshield?
The more I look at things I don't think a flat hood is going to clear. I would really like one but a small cowl style is probably what I will have to go with for clearance.
Were you happy with VFN's quality?
Old 02-04-2017, 10:16 PM
'Bird Director
y2k_ta's Avatar
Yes, it goes back to the windshield. I thought the quality was good. They were very concerned that I was trying to order a hood that wouldn't fit my car, but for what I wanted to do it was perfect. It is much larger than a factory hood, and I did cut it down on the front , both sides and the rear. I used Fivestar Bodies hood hinges at the rear so I can have a lift off hood and a hinged hood since I will be alone most of the time at the track.
'Bird Director
y2k_ta's Avatar
Old 02-05-2017, 12:07 PM
Knick's Avatar
Smile
I contacted VFN about the flat hood as I could not find one online, it looks like my only option at this time. It did look like maybe a stock style Fire hawk hood might work, but I did not see any that were lift off. At this point I am thinking stock style hood and make a shaker style scoop.
Thanks again for your help.
Quick Reply: Flat or low cowl hood
