2001 Trans Am RPO Codes
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
10U - PAINT, ARCTIC WHITE
192 - TRIM, EBONY
19I - INT TRIM, EBONY
1AY - ORDER MODIFICATION STOCK
1SA - OPTION GROUP
6BT - COMPONENT FRT LH COMPUT SEL SUS
7BT - COMPONENT FRT RH COMPUT SEL SUS
8TJ - COMPONENT RR LH COMPUT SEL SUSP
9TJ - COMPONENT RR RH COMPUT SEL SUSP
A31 - POWER WINDOWS
AAA - STANDARD EQUIPMENT PROCESSING OPTION
AG1 - POWER SEAT, DRIVER 6-WAY
AK5 - DUAL FRONTAL AIR BAGS
AQ9 - CUSTOM BUCKET SEATS W/ADJUSTABLE LUMBAR SUPPORTS
AU0 - REMOTE KEYLESS ENTRY
AU3 - POWER DOOR LOCKS
BBS - HURST SHIFTER
C60 - AIR CONDITIONING, CUSTOM
CAF - HANDLING CHARGE-ST. THERESE TO AMERICAN SUNROOF
CC1 - LOCKING HATCH ROOF, REMOVABLE
DE4 - HATCH ROOF SUNSHADES, REMOVABLE
DG7 - DUAL POWER SPORT MIRRORS
DL5 - DECAL ROADSIDE SERVICE
FE4 - RIDE & HANDLING SPECIAL SUSPENSION SYSTEM
FE9 - 50-STATE LOW EMISSION VEHICLE
G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
GU6 - 3.4 RATIO REAR AXLE
IL2 - TRIM INTERIOR DESIGN
J65 - BRAKES, PWR 4-WHL,DISC FRT & RR
K43 - 102 AMP GENERATOR
LS1 - 5.7 LITER SFI V8 ENGINE
MM6 - TRANSMISSION, 6-SPEED MANUAL
MN6 - TRANSMISSION, 6-SPEED MANUAL
NF7 - FEDERAL LOW EMISSION
NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT ****
PBT - TEMP. WHL & TIRE-UPFITTER DLVY
QB6 - 17" HIGH POLISHED ALUMINUM WHEELS
QFK - TIRES, P275/40ZR17 SPEED RATED
R7X - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY
R9P - POWER PACKAGE INCLUDES: POWER DOOR LOCKS RETAINED ACCESSORY POWER, POWER WINDOWS INCLUDING EXPRESS DOWN DRIVER'S SIDE DUAL POWER SPORT MIRRORS POWER ANTENNA
SLM - SALES STOCK ORDERS
STE - ASM PLT ST. THERESE
T43 - SPOILER, REAR DECK LID
T78 - HEADLAMP CONTROL DELETE
U75 - POWER ANTENNA
UA6 - THEFT DETERRENT SYSTEM
UB3 - RALLY GAGES W/TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS
V12 - POWER STEERING COOLING SYSTEM
V73 - VEHICLE CERTIFICATION U.S.
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER, INCL. CLOCK, SEEK UP/DOWN, REMOTE CD PRE-WIRING, MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 17" HIGH POLISHED ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * SPECIFIC LOW RESTRICTION DUAL EXHAUST SYSTEM * SPECIFIC TUNED SUSPENSION * POWER STEERING COOLER WS9 - FORMULA OPTION
Y82 - TRANS AM OPTION
Anything special about this?
192 - TRIM, EBONY
1SA - OPTION GROUP
A31 - POWER WINDOWS
BBS - HURST SHIFTER
U75 - POWER ANTENNA
LS1Tech Administrator
Received 1,483 Likes
Only BBS (Hurst Shifter) stands out, though not super rare either, otherwise it's a pretty typical 2001 WS6 car. Not a whole lot of optional equipment to order on a WS6 in the first place, but yours was ordered without two optional items:
NW9 - Traction control
U1S - 12-disc CD changer
Beyond that, the only other options were limited to the seats (you already have the upgrade seats which are common - AQ9, inflatable lumbar support), driveline options (manual vs. auto related items), interior and exterior color, regional emissions equipment codes, and roof type (t-top vs. convertible, yours being CC1 - t-top.)
