Flat or low cowl hood - LS1TECH
Thread Tools Search this Thread
Old 01-28-2017, 10:20 AM   #1
Default Flat or low cowl hood
Hey guys
I have a firehawk with Joe Van Overbeek 5"cowl hood. I need a lower hood so I can drive it on the street. The cowl has been cut so I need one that goes back to the windshield and it has to be a lift off. I thought I would check in here to get recommendations for a quality hood.
Thank you!
Knick is offline   Reply With Quote
Old 01-29-2017, 08:26 AM   #2
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
There isn't a flat hood available unless you do what I did. I bought a VFN extended nose hood for their fiberglass front end. It is too large on every edge for a stock nose, but trimming it down on each side worked like a charm.
y2k_ta is offline   Reply With Quote
Old 01-29-2017, 08:28 AM   #3
'Bird Director
y2k_ta's Avatar
Old 01-29-2017, 09:13 AM   #4
Quote:
I cant tell in your pic, but does the back of the hood go all the way to the windshield?
The more I look at things I don't think a flat hood is going to clear. I would really like one but a small cowl style is probably what I will have to go with for clearance.
Were you happy with VFN's quality?
Old 02-04-2017, 10:16 PM   #5
'Bird Director
y2k_ta's Avatar
Yes, it goes back to the windshield. I thought the quality was good. They were very concerned that I was trying to order a hood that wouldn't fit my car, but for what I wanted to do it was perfect. It is much larger than a factory hood, and I did cut it down on the front , both sides and the rear. I used Fivestar Bodies hood hinges at the rear so I can have a lift off hood and a hinged hood since I will be alone most of the time at the track.
Old 02-04-2017, 10:16 PM   #6
'Bird Director
y2k_ta's Avatar
Old 02-05-2017, 12:07 PM   #7
Smile
I contacted VFN about the flat hood as I could not find one online, it looks like my only option at this time. It did look like maybe a stock style Fire hawk hood might work, but I did not see any that were lift off. At this point I am thinking stock style hood and make a shaker style scoop.
Thanks again for your help.
Related Topics
Thread Thread Starter Forum Replies Last Post
trufiber 4'' cowl hood. Sail Hatan Appearance & Detailing 3 02-28-2016 08:07 AM
Cowl Induction Hood for 98-02 Trans Am? AmericanMuscle830 Pontiac Firebird 1967-2002 2 09-02-2008 01:22 AM
Cowl Hoods jeff5076 LT1-LT4 Modifications 2 03-20-2007 05:31 PM
Cowl Hood foggedz LT1-LT4 Modifications 24 03-05-2006 09:17 PM
Fiberglass Fabricators Inc. ...? slik98z Appearance & Detailing 8 01-09-2004 02:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
