Need Help. LT1 don't run... - LS1TECH
Thread Tools Search this Thread
Old 02-09-2017, 08:52 PM   #1
Ron G's Avatar
Default Need Help. LT1 don't run...
1995 Trans Am LT1 auto. Has spark and runs on starter fluid. Fuel pump and tank were just replaced due to the car sitting for like 9 years (what fun) and now reads good fuel pressure at the rails.
The fuel injectors are not pulsing. I only get a positive reading on both wires and each injector during crank. So I am assuming this is related to something between the PCM and optispark.
Where I stand after todays testing is when taking voltage readings at the 4 wires that go to the optispark from the PCM I have good 12v, good ground, and 5v on each of the resolution wires from the PCM. However when I plug the harness back into the optispark, one of the resolution wires is dropping the 5v out almost down to zero volts.
Does anyone know if this points more towards a bad optical sensor or a bad PCM? Or are there any other tests I can conduct to help point me in the right direction or confirm anything? I don't have a spare PCM to plug in and test and I also do not have another known good optispark unit to plug in and test.
I tried to get readings from my old Snap On code reader that has the adapter and chip card to work with that wonky OBD2 port that is actually an OBD1 and it is not throwing any codes (reader says no codes) nor is any light flashing on the dash.
It is not the VATS has I have crank, the security light goes out after a few seconds of ignition on, and no trouble codes such as would happen if the TDM was not sending a signal to enable fuel injectors.
Any help would be greatly appreciated.
Ron G is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Stop Replacing Opti's!!!! hrcslam LT1-LT4 Modifications 45 10-05-2016 11:39 PM
Injectors not pulsing..need help 1976CamaroGuy PCM Diagnostics & Tuning 13 12-31-2015 10:32 AM
Blew up PCM while cranking engine..HOW! goatcrazy Conversions & Hybrids 6 04-12-2010 07:39 PM
New Opti Still no Spark... WTF!!! Cross LT1-LT4 Modifications 30 11-15-2008 11:50 PM
LTCC problems!!! PLEASE HELP KillinFormula LT1-LT4 Modifications 10 11-24-2006 04:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
