AC compressor install - LS1TECH
Thread Tools Search this Thread
Old 03-01-2017, 08:56 AM   #1
bleepster's Avatar
Default AC compressor install
hello. I have a 2002 Firebird (V6). the AC compressor is making a grinding noise. I know its the clutch plate in the front. It started last spring. so as a "temp" fix, i re-ran the serpentine belt to by-pass the ac compressor. one of the side effects of that is it can make he alternator chirp now and then.
anyway.....
we never use the AC. I want to replace the compressor and put the serpentine belt back to original to eliminate the alternator chirp. will i have issues with reinstalling the new compressor and NOT charging it with freon?
we never use AC anyway with t-tops.
thoughts?
bleepster is offline   Reply With Quote
Old 03-01-2017, 04:48 PM   #2
Jaxem's Avatar
I have no freon in my system and the car is just fine with it, the pressure switch keeps the compressor from ever coming on if there's no charge in the system, so no real danger of anything happening. Just be sure to have the system professionally evacuated, freon is nasty stuff
Jaxem is offline   Reply With Quote
Old 03-02-2017, 06:56 AM   #3
bleepster's Avatar
^^thanks - i appreciate the reply. I'll have the freon properly evacuated.
Related Topics
Thread Thread Starter Forum Replies Last Post
Moved Alternator - Need Custom Length Serpentine Belt Frizzle Fry Conversions & Hybrids 20 05-01-2016 09:39 AM
WTB Fbody AC Compressor, Tensioner, and IAT plug 97ramsst Parts Wanted 1 04-16-2015 08:08 PM
A/C Compressor Clutch Swap...Guru's Help... TomM Conversions & Hybrids 1 07-16-2009 06:08 AM
AC Compressor "delete" bypass pulley Bones Z28 LT1-LT4 Modifications 8 07-27-2008 08:14 PM
AC Compressor Relocation--One approach Geezer's Garage Conversions & Hybrids 21 01-02-2008 06:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
