Headllight issue
Headllight issue
Can anyone give a suggestion as to how to fix my passenger light not working correctly.
Both ds and ps have brass gears and MOTORS both work just fine however if I turn on the lights the drivers side pops right up....... passenger side does not.
If i got and pop hood and turn the manual adjusted even a $%^& hair it will work just fine.
when turning off they always both go down no issues. The next time i go to use them sometimes it will work just fine with both however most times it does not.
Any help would be greatly appreciated
Headlight Procedure
You turn on your headlights and one of the two pops up while the other remains in the down position.
1.) Turn off your headlights to lower the raised one back down. Now, simply turn your headlights back on and see if both respond and lift up together.
2.) If after at least three tries your headlights are not both raising up, turn off your headlights to lower them back down. Pop your hood and manually raise the one headlight that was not popping up. Raise this headlight all the way up until the **** can not turn anymore. Now, go back and turn on your headlights. Both should now be raised. Now turn the headlights off and on and cycle them to ensure both will now raise and lower, which they should now be able to do. You may need to fiddle with them again after you shut your car down, test cycle them for a day or two and see how they act.
3.) You have tried the second step but after test cycling the headlights, the one headlight that would not raise will now either not lower back down or it will not raise itself again, or the other headlight is now acting up. Here you will have to play with manually raising or lowering the headlight that was not working and unplug it before trying the cycle process again. With the headlight manually raised or lowered and unplugged, turn on your headlights and now plug it back in. The headlight should automatically raise or lower itself. Now try to cycle the headlights at least three times to see if they will now both lower and raise together. If the headlights raise and lower together, hopefully the problem is solved for now. You may need to fiddle with them again after you shut your car down, test cycle them for a day or two and see how they act.
4.) If your headlights are still not raising or lowering together, or for some reason that one stubborn headlight is not raising or lowering itself after these manual adjustments and unplugging, you need to make sure both headlights are in the lowered position, and your last resort will have to be resetting your computer by first unplugging the negative battery terminal followed by the positive battery terminal, and waiting at least 30-minutes before reconnecting the battery. After enough time has elapsed, plug the battery back in and test the headlights for synchronized operation. If this does not solve the problem, try disconnecting the troublesome motor and detach it from the headlight lifting arm. Manually spin the gear 180-degrees and then reattach the headlight lifting arm. Plug the motor back in and see if this adjustment helped at all!
(For those who are ****, anytime you unplug the battery your PCM must relearn the IAC position. You have to perform the IAC relearn procedure. This procedure is available on-line, I use the procedure listed in a repair-manual.)
5.) If step four does not solve the problem, it may be time to see a specialist and get their opinion!
Save the manuals!
It could also be a balky module. But first, I'd test to make sure it isn't the gear. If it's the module, you should be able to open the hood and tap on the module to get things to work. If that makes the motor move, then you'll know its not the gear. We have a fix for the module now: https://ls1tech.com/forums/pontiac-f...l#post19594997
Save the manuals!
The modules aren't this complex or "smart". If you look at the schematic linked above, they run off of a simple IC and relays. They will self-reset. The only way one light will stay up and the other down is if a motor has a stripped gear or if it isn't getting power through a wire/connector or the module.
So, when you quote my fix suggestion of rotating the gear 180 degrees, this was not the result of a stripped gear, as you so adamantly claim! It was a desperate attempt to find a solution to make my motor with this metal gear work properly!
Now, I know for certain the motor was over-torquing because there is a plastic tab on the headlight housing meant to stop the lift arm, connected to the gear shaft, from continuing to rotate the gear. When I popped the hood to check it out, on those days the headlight was not going back down, the manual **** was so damn tight I had to use both hands to crank the headlight back down! After my 180 degree rotation fix, it doesn't get stuck in the up position, but on some days it won't raise with my other motor, which is still using the plastic gear.
Save the manuals!
If you experience this again, you might try flipping the motors side-to-side. If the problem stays on one side and doesn't follow the motor, that will confirm a module issue.
This is still weird. I'm wondering if you might have an intermittent issue with your headlight module. It has circuitry that senses when the motor has reached the stops. (The plastic covers that the arms door arms engage at the top and bottom of the motion.) When that sensing happens, the module cuts power to the motor. If the power isn't cut... the motor will jam as you are describing. (It shouldn't have anything to do with the motor or the gears.)
Thinking some are confused on the issue.
When i first start car.... I go to turn on lights (Rarely driven let alone at night)
The drivers side always pops up....passenger side not always. I can go turn the manual thing to turn up and it works just fine (as in use my allen key and turning even 1/64") and it pops right up on its own.
I do not think there is ANY gear issue as it works just fine for say the rest of the day or me turning lights off and on. The next time i go to drive car ...say a week later..it may or may not come up.
Hence my confusion. I am leaning more towards maybe I should give:
as the only thing I did different was pull assembly out on passenger side to "check connection" for water and to use dielectric in connection. I remember testing it with assembly sitting on core support and it work just fine however i also remember manually adjusting to lower/ raise and not sure if that confused system.
I also adjusted the stop? that allows the lid to be flusher with hood as when i bolted back in place it was not in exactly the same location as before.
Thanks again for the thoughts etc. Will try this weekend.
Save the manuals!
There is a failure mode where it could be the door module. To check that the next time this happens - look to see if the headlight is on with the door shut. Then tap the headlight door module.
If the light is off, you probably have a problem at the motor connector.
If tapping the headlight door module causes it to work, then you could have the cold solder joint problem in the module.
The other thing to do would be to have someone stand at the light when its acting up. Have them put their hand on the motor and feel if its running when you try to open the doors. If it runs and the door doesn't move, then you know it's a gear problem.
I hope you don't mean you altered the plastic housing headlight lifter arm stop?!
I had a similar issue where the passenger headlight would only go up or down whenever it felt like it. So i had to go out and manually raise it myself. It wasnt often, but nonetheless it did occur. However, mine wouldnt go down sometimes. So i replaced the motor and never had that problem again.
