lights
Old 05-25-2006, 03:54 PM
04goatinmass's Avatar
Default lights
today i noticed my fog lights r not working anymore.the switch inside lights up.any thoughts?
Old 05-25-2006, 05:52 PM
Captainofiron's Avatar
there is a relay in the box under the hood for the fogs, move them around and see if the light go back on, other than that check the switch inside, check if your lights are in low beam, and finally check the fog lights themselves and the harness going to them
Old 05-25-2006, 06:55 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Maybe the bulbs have both blown?
Old 05-25-2006, 08:00 PM
thanks guys.i bet i can take a dc volt meter and with the lights on see if i get anything.just weird im sure both bulbs didnt blow.those stock ones are pretty cheap.any thoughts on replacement without changing housings?
Old 05-26-2006, 12:09 AM
'Bird Director
y2k_ta's Avatar
I've had both bulbs go out rather close together before, so I wouldn't totally rule that out. I've found that the Sylvania brand seems to last much longer as a replacement bulb for the stock lights. Whatever GM used didn't last very long at all.
Old 05-26-2006, 12:27 AM
i looked up the silverstar 893 .will those work.also is there a write up for removing those housings i wanna clean them up.
Old 05-26-2006, 07:24 AM
'Bird Director
y2k_ta's Avatar
Here are the two driving light bulb brands that I've had the most success with on my 'bird. The Sylvania 880 & Napa 880.
Quick Reply: lights
