Removing canopy
Old 03-30-2007, 01:48 PM
phantomzer0's Avatar
Default Removing canopy
Does anyone know how to remove the canopy on a firebird / camaro? The area is just behind the t-tops and divides them from the rear hatch. Sometimes it's refered to as a sail panel. At any rate, I need to remove mine and I'm not quite sure how to go about it. I also need to know how to re-attach it, as I heard some sort of glue is used. Any help would be great. Thanks!
Old 03-30-2007, 02:23 PM
On the tree
Sneakyws6's Avatar
I am pretty sure that it will be ruined when you remove it and will have to be replaced with a new sail panel.
They use a bonded glue when those are glued on at the factory.
Old 03-30-2007, 02:31 PM
edwardswb's Avatar
I'm not sure but there may be a how-to somewhere on this. Anyway, it involves a piano wire and a whole lot of patience. You have to cut through the glue with the wire.
Old 03-31-2007, 08:54 PM
azvforce's Avatar
Well there is steel bracing that runs up and over. It is skinned with fiberglass that is glued on very well. I pulled one apart and alot of the fiberglass came apart, ruining the fiberglass skin.
Old 04-01-2007, 08:44 PM
wabmorgan's Avatar
Why???? Are you wanting to do this????
Old 04-02-2007, 11:26 AM
fastgm_silver02ws6's Avatar
what he said!
why could you possibly NEED to remove that panel. ALOT of the body strength runs throught that panel.
Old 04-02-2007, 09:22 PM
da_noob's Avatar
amen to that statement
Old 04-02-2007, 10:03 PM
2000badbird's Avatar
it cannot be taken off with out damaging it i asked a trusted body guy who has worked on many f-bodys at the dealership i worked at he said he has removed quite a few since 93 and none have come off with out bein damaged. im having mine painted black like a camaro thats why i asked so now im waiting to paint the whole car before i do that
