Weather Stripping
Weather Stripping - Huh... not one person of 25 views knows ANYTHING?!
Alright, my right door's around the window is hashed from either trying to get in with a coat hangar or a dog (previous owners). My right window doesn't seem to puff up enough to make a seal on the window towards the back. So basically I figure I need new weather stripping. Would you say #6 is what I need?
http://www.fbodymotorsports.com/inc/sdetail/13598
Also, would this be also the correct P#s?
That's from the LT1 Newbie Part Numbers FAQ. Has damn near every part number you could think of.
On that note, anyone know where to get it cheaper than $220? I have to fix my Drv window AGAIN so this is starting to suck. I can't even wash my car and I haven't drove in the rain yet either :\
Thanks in advance. Any info helps (Even a Yes on it being #10)
EDIT: I checked GM Parts Direct on those 2 Part Numbers and I'm a bit leery. They're only $32 each, but if that's it, it'd be awesome. I have a feeling it's #9 on that diagram from the first link. Which I really don't understand what that is.
EDIT2: NM that seems to be this piece
http://shop.com.edgesuite.net/ccimg....g_39111799.jpg
Originally Posted by ACW
window outer sealing strip (93-02), RH = 10284222
window outer sealing strip (93-02), LH = 10284223
