Cutouts
Old 05-10-2007, 04:37 PM
JayErnie's Avatar
Default Cutouts
Where would you put your coutout on your Bird's exhaust system:
-x2 cutouts right behind the header
Or
-x1 cutout right behind the Y pipe
Any other suggestions?
By now I'd just do that on the stock exhaust, but let's say I put some mid or long tube headers, how could I fit a cutout setup for performance.
Old 05-10-2007, 09:56 PM
kevinclark09's Avatar
my cutout is at the end of the I pipe (the one after the Y pipe) right before it goes into the muffler. i think it sounds pretty good, but some LT headers would set it off nicely
Old 05-10-2007, 09:59 PM
c0ncEpT's Avatar
Mine is in the same place, And Lt's did set it off nicely
Old 05-11-2007, 01:03 PM
1 BAD BIRD's Avatar
I agree. Right on the passangers side directly under the passanger backseat is a small indentation that a cut out can be put and not cause any ground clearances.
Bob s
Old 05-12-2007, 01:10 PM
02TransAm/Batmobile's Avatar
I've put mine about right there also. Plus, it makes it easier to cap on or uncap if you need it quiet.
Old 05-12-2007, 01:36 PM
Captainofiron's Avatar
mine are right behind the headers, sounds better lot louder lot meaner, plus at the high end the engine screams. has lots more pull at high speeds
Old 05-12-2007, 07:30 PM
LT4hotcam's Avatar
Bob s
Thats exzactly what i did.
Old 05-15-2007, 06:20 PM
JayErnie's Avatar
Is the exhaust tubing right under the pass. backseat round O or 0 like the section who passes by the driveshaft?
Old 05-16-2007, 06:55 PM
1 BAD BIRD's Avatar
It is perfectly round, not oval like the drivers side y pipe section.
Bob S.
Old 05-16-2007, 11:58 PM
imma_stocker's Avatar
Put a bead of oil down your exhaust from headers back and turn the car on. Wherever the oil isn't burned is the farthest upstream you should put a cutout. Backpressure is important.
That's what I heard, not sure how accurate it is.
Old 05-17-2007, 12:28 AM
Optimus_Prime's Avatar
Why not put on all 3?
