79 TA Engine swap
79 TA Engine swap
Hey all, looking at swapping my 403 Olds for an LME 408......any ideas on what I'm gonna need to do to get this to fit? I know I need the new harness..Thanks
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
frame mounts and possible front crossmember/oil pan clearance issues may arise.
Check out the conversion forum to see if anyone has attempted this swap on a '79 model. I know one member did an LS1 swap on a 76 'bird.
Derek
Derek
Here are a couple of good writeups I have bookmarked. Both 2nd gens.
http://people.virginia.edu/~mec2d/ls1swap/firebird.htm
http://www.cardomain.com/ride/2073647/1
LME is a sponsor on this site... the 408 is an iron block LQ4 with like a 4.008ish bore and 4.0 inch stroke or something similar... anyway, its an engine regardless. And yes its doable, a guy from back in Missouri did one into his 78 camaro, and it fit pretty good, just had to modify a regular set of pacesetter headers to fit... but not a big issue... ls1 with a Trex... guys are from 417 motorsports... good luck...
