Any Bird owners change drl/turn signals yet?
Old 07-30-2007, 12:13 AM
YOOFORMULA's Avatar
Default Any Bird owners change drl/turn signals yet?
If so, what did you use? Mine are yellow and cracked and I want to upgrade to something else. Yes, I TRIED to use the search but that is a joke.
Old 07-30-2007, 03:02 PM
BLK02TA's Avatar
Sell it and buy a T/A?
Old 07-30-2007, 03:59 PM
junior28570's Avatar
I replaced mine with factory replacements from rockauto.com ... they look 10X better than the wore out ones.
If another look is what you're after, they make a "black-out" kit ... check the WS6store
Old 07-30-2007, 09:17 PM
YOOFORMULA's Avatar
Nah, they are too slow thanks for the input Nan but ummm
did you already head back to the base or are you still home?
Old 07-31-2007, 07:06 AM
nytmare1's Avatar
I replaced both of mine with stock lens/housing units from gmpartsdirect. I purchased new bulb sockets from Advanced Auto.
Tip: Before installing the housing, seal the gap between the lens and the housing with plumbers epoxy. It'll help keep the moisture out.
Marc
Old 07-31-2007, 11:31 PM
99'CajunFirehawk157's Avatar
Seems like a nice bead of clear silicone would be best for this, IMHO.
Old 08-01-2007, 06:57 AM
nytmare1's Avatar
Clear silicone will work. I used plumbers epoxy (I used the clear type) only because it does the same thing, but is resitant to mold and mildew. Some silicones are not. And since that area can get pretty wet...
Marc
Old 08-08-2007, 10:14 AM
ICRAZY6's Avatar
I changed the yellow bulds for clear. It looks better in my oppinoin.
Old 08-08-2007, 10:42 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I've seen people banned for these kind of comments.
Old 08-08-2007, 11:21 AM
tylerdj's Avatar
I bought replacements from a company on ebay...I think it wasn't much more than $50 for both housings. One of the best appearance mods I've done to my car was getting rid of those yellow cracked housings and replacing them with some clean clear ones.
Old 08-08-2007, 12:53 PM
Rancor352's Avatar
I bought clears off from ebay. If you go that route make sure you seal them good, wouldn't want any water to give you hell.
