Front license plate
Front license plate
Hello, I'm new here so go easy on me.
I will soon be the proud owner of a 1996 Firebird Formula. Unfortunately, here in Ca, we have to have two license plates. The car does not currently have any way of mounting a front plate. Does any one here know of a way to mount it or a factory bracket for one?
teh PuRpL3z
I don't know how legal it is in California, but it's technically legal here in Washington State. I've actually moved it upward slightly so the wiper does not block it.
I bought it from this place.
http://www.gppinc.com/
Thanks for the thought, but your not allowed to attach anything to the windshield either. With my luck I'd get two tickets if I did that.
teh PuRpL3z
I had a 1997 Trans AM, and I can sympathize with you...The front end of the LT1 style firebird is so clean & simply - it should be a crime to put a front plate on the nose!
But here is NY we also use 2 plates. When I bought my '97 new the dealer installed a front plate that GM supplied, it it designed to mount fairly nicely onto the front bumper.
I did get tired of looking at that front plate, removed the bracket, and the body shop fill in the 3 mounting holes in the bumper & re-painted the nose.
It looked GREAT clean like that. I then mounted the plate in the front window, but like said above that really isnt legal either.
Its a tough call, with the re-designed front the of the LS1 style, there is a place for the plate - i can easily add/remove the plate cover in a few minutes.
Good luck.
Good luck.
here in Texas the law says something along the lines that the plate must be visible from the front of the vehicle, but if it doesnt have any provisions for the plate, I say drive without it, and when you get a ticket, tell the judge, hey its an older car, doesnt have a place to mount it.
Maybe you will get lucky
Thanks for all the replies. I'll probably take my chances with the plate in the window idea. It really will kill the look of the front end if I tag it with a plate.
Who knows, maybe I can come up with something creative.
Here's what the Code says:
5200. (a) When two license plates are issued by the department for use upon a vehicle, they shall be attached to the vehicle for which they were issued, one in the front and the other in the rear.
5201. ...and the front license plate shall be mounted not more than 60 inches from the ground...
It's a little vague. The windshield thing may actually be OK.
I had a 94 Formy. I went to the dealership and got me a frame that was a form fit right under the point on the front.
Does this help?
Originally Posted by LS1Tuner_06
ARE LS1's the only ones that have that plastic thing below the bumper. idk if the lt1's have that piece. i've just seen ppl put them under there...?
I have seen some LT1's with and without the provisions for the license plate up front, mine originally had it, but an idiot in a excursion hit my parked car in the parking lot of a target and just took off, didnt wait, didnt leave a note, well needless to say it owned my license plate and the little bracket, so I just took it off
but from what you posted, it seems like the windshield would be ok its on the front, its not more than 60" up
