98 TA Fog lights in a 97???
Old 08-27-2007, 09:02 AM
rmpitzer's Avatar
Default 98 TA Fog lights in a 97???
I have a 97 Trans Am, and it needs new fog lamps. Does anyone know if the 98-02 lamps (the lens and reflector only) are the same as the 93-97? Will they mount in the 93-97 brackets (which I know are different).
Finding decent used 93-97 fog lamps is difficult, but the newer ones are easier to find, so I wondered if I could mount them in the older brackets.
Thanks!
-Rich
Old 08-27-2007, 09:13 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I have a set of '98-'02 driving lights/brackets. This info might help you determine whether or not they're the same.
Info on bracket:
Made in USA
Blazer International
#10019 T
Back of light housing:
Made in USA
SAE F 93 Guide 2F
US Patent #4905,133
Blazer
Front of lense:
SAE F 96 GM 5Z
Old 08-27-2007, 09:16 AM
rmpitzer's Avatar
Thanks for the info. I'll look at mine tonight when I get home and compare. Does the lamp housing mount on the bracket with 2 plastic rivets on the bottom of the housing (pivot point) and a top spring loaded adjuster screw for alignment?
Old 08-27-2007, 09:45 PM
'Bird Director
y2k_ta's Avatar
Yep, that's exactly how they're mounted.
Old 08-28-2007, 07:53 AM
rmpitzer's Avatar
Excellent, thanks once again. And....the lamp housing has the same exact identification on the back as yours, so I think they are the same, just the brackets are different.
-Rich
Old 04-08-2022, 10:50 AM
nastyiroc's Avatar
Bump can anyone confirm they are the same?
Quick Reply: 98 TA Fog lights in a 97???
