Shifter on the column
I have one of those rare shifter on the column automatic 1967 Firebirds. My shifter handle is pretty loose and the shift indicator plastic is horribly yellowed.
I can't find a single vendor yet who carries any steering column parts for the automatic transmission. (Do you know of any?)
I was told to check out Chevy truck restoration parts websites and those that I've called either haven't a clue or only have it for a manual transmission.
Is there anything I can do -- including replacing the entire column -- to solve this? I don't mind buying a new column and parts if it will fit in my car. Price is no option.
But I need to get this done, that loose shifter irritates me and let's face it, the rest of the car looks so good and that looks so bad, especially with a non-threaded shifter **** duct taped in place.
try ames, if no luck there, go to https://ls1tech.com/forums/showpost....0&postcount=10
I am sure one of the guys over there has a similar problem
---URL EDIT BY MODERATOR. LINKS TO OTHER FORUMS ARE NOT ALLOWED---
y2k_ta
y2k_ta
