Bouncy Headlight Woes
Old 11-20-2007, 01:56 PM
Destru6969's Avatar
Default Bouncy Headlight Woes
When I have my headlights on, my passenger side headlight bounces while driving. I looked at it today and it appears the rivet in the middle of the actuator arm has a bushing or something that's worn causing it to bounce. Has anyone had this problem? And if so, what do I need to fix it?
Old 11-20-2007, 02:02 PM
Wing Zero's Avatar
The times I have seen that I just get a new arm from the dealer or classic ind. But double check the bolts aroound the head light and motor to make sure nothing is loose.
Old 11-20-2007, 03:13 PM
Destru6969's Avatar
Good deal! I'll call and check on it. I did double check, it's definately the arm.
Quick Reply: Bouncy Headlight Woes
