What is that stuff in my 67s trunk??
Hi
just got my 67 Firebird Convertible from Texas to Norway yesterday.
Started to do some work on it today... most things need to be done to it, but thats what I am looking forward to.
The thing I wounder about is:
On both sides all the way to the back of the trunk, i have a container of some sort. It is cylinder formed and is approx 4-5 inches i diameter and maybe 8 inches tall. It has a bolt on the op of it. they are not connected to anything.
And they weigh at least 10 pounds each.
Can anyone tell me what this is? And what it`s for?
Will post some pictures but forgot my camera in my fathers garage.
Thanks for the help.
They have something to do with it being a convertable. Saw something about them on HorsePower TV a while back. Don't remember the exact use but they were really important to keep. If I can find out more I will post again. They are building a 69 convertable.
Me too. Saw that HP TV show as well with the Blue Convert. but for the life of me can't remember what they said the container's were for.
Balance weights?
If there are hoses connected to the bottom traveling thru the floor, possibly they were containers for some sort of liquid tire chain to drop on the rear tires in inclement whether. Back in the day alot of hairbrain stuff like that was sold thru Popular Mechanics magazines, etc. Check the trunk of early Birds and Camaro's at the next car show in Norway?
Best of Luck on your ride!
Balance weights?
They are called "cocktail shakers" by most people. They are basically ballast weights filled with automatic transmission fluid to help balance out the corners of the convertibles to give a better ride.
The following users liked this post:
tuske427 (03-20-2022)
Ok, thank you for that info.
Will rent some "test drive" licence plates next weekend and go to a car show... will check on other first gen f-body cars if there are any there.
So I guess I just can take them out and replace them with a pair of 10" subwoofers in enclosures then?!
Will also probably put the battery in the trunk.
Just have to see how the project evolves.
They may be canisters filled with cocain that was smuggled overseas in your car without you knowing!! Get a gun! Quickly!!
LMAO! Just kidding, but when I read the title of the thread I was thinking bodies, but heavy canisters sounds more like a drug embezzlement.
Other than the BS above, I'm no use to you as I haven't a slight clue!
Swat
Swat
Found the ones in the front fender
Read a lot about "coctail shakers" on the web now.
And they are very important for the stability of the convertible at speed.
So I will keep them in my car!
Just very happy that they where there. Or else I would drive my car and never find out what that made it feel like driving with four bent rims.
Thank you for the info
They are canisters filled with lead shot beads to add weight over the rear wheels. That is why Firebirds "jumped" off the line, while Camaro's burnt their tires off. They weight about 50# each. Only the Firebirds had the wheel tubs drilled and spot nuts welded in for the mounts. Smart Camaro owners bought the canisters from Pontiac and install them.
