Blinkers wont flash, window motor
Old 09-16-2008, 08:43 PM
cdale_sam@yahoo.com's Avatar
Default Blinkers wont flash, window motor
I replaced the falsher and fuse, the hazzard lites flash and work, but when i put on a blinker it jus lites up, it dosent flash, i have know clue how to fix it, also the drivers side window dosent work, the pasanger does, it doesent make any noise or slide up and down, is this a bad motor or just a switch
Old 09-16-2008, 09:16 PM
96onele's Avatar
The turn signals have a seperate "flasher" relay. Different part # too.
Old 09-16-2008, 09:19 PM
where is that flasher located, i found the 1 under the dash on the left side by the stering colum, but i guss its for the flashers
Old 09-16-2008, 09:25 PM
Copy & Paste Moderator
VIP1's Avatar
check out this sticky:
https://ls1tech.com/forums/showpost....18&postcount=7
Old 09-16-2008, 09:26 PM
Old 09-16-2008, 09:31 PM
that still didint tell me where the flasher for the blinkers are.
Old 09-16-2008, 10:02 PM
t/a98's Avatar
keep looking, i think its more toward the door, its been a while, but it was really really hard to find mine too, and when you find it make sure its full of blinker fluid
Old 09-16-2008, 10:37 PM
*98TransAm*'s Avatar
on my car, the hazard flasher is on the left, the blinker flasher is on the right.
Old 09-16-2008, 11:28 PM
VIP1's Avatar
No.... but ....
If one side works and the other side doesn't then the problem is not the flasher. If both sides don't work, then it may be the flasher but its a good idea to perform the following test anyway to make sure.
The 4th-gen f-body has two flasher modules. One for the left/right signal and one for the hazards. The same flasher operates both the left and right signals. That is why it cannot be the problem if one side works and the other doesn't.
Did you do the test?
The two flashers should be near each other.
Old 09-16-2008, 11:58 PM
LS1stunna's Avatar
+1
Old 09-17-2008, 06:32 PM
niether side works, they jus stay on, hazzards work
Old 09-17-2008, 06:43 PM
what does the blinker flasher look like, is it a round 2 prong like the hazzards, or is it this square grey relay lokin thing that says orion, it has 2 wires and lookslike it could b a flasher, its near the hazzard flashers
Old 09-17-2008, 10:46 PM
1995blacktattop's Avatar
mine was round and 2 prong IIRC, the top of it was like an unpainted aluminum almost. and its supposed to be clipped either to the steering column or the dash on the right side of the column. the clip was still on it (round metal thing) but i found mine down behind the center console right about where the bottom of the dash meets the console hidden down there (it wasnt clipped to the column like it was supposed to) and i had the exact same symptoms being described. the hazards worked fine but the turn signals didn't blink
it looked like this only unpainted (i think most of the replacements are painted)
Old 09-18-2008, 02:08 PM
i found the flasher, and replaced it, problem solved, thanks
