BMR Launches New Product - G8 Trailing Arms (TCA026) - LS1TECH
Pontiac G8 2008-09 & Chevrolet SS 2014+ LSX based RWD 4-door sedans
Thread Tools Search this Thread
Old 02-04-2009, 02:40 AM   #1
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Thumbs up BMR Launches New Product - G8 Trailing Arms (TCA026)
BMR Fabrication Trailing Arms for the Pontiac G8
Stabilize your Pontiac G8 caster settings and minimize wheelhop under performance driving conditions with a set Trailing Arms from BMR Fabrication. Superior to the factory stamped steel arms, BMR Trailing Arms are composed of 1” x 2” x .120 wall rectangular steel and 3/16” CNC laser cut steel plates. In contrast to the open factory rubber bushings, the BMR Trailing Arms (TCA026) utilize fully-fluted, greaseable, low-deflection polyurethane bushings for fluent operation. Available in black hammertone or red powdercoat finishes.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com, email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
BMR Launches New Product - G8 Trailing Arms (TCA026)-tca026r-press-release-pic-detail.jpg
BMR Suspension is offline   Reply With Quote
Old 02-05-2009, 10:06 AM   #2
Bad Habit Bird's Avatar
Does BMR have any plans for a lightweight k-member / a-arm setup?
Bad Habit Bird is offline   Reply With Quote
Old 02-05-2009, 01:50 PM   #3
BMR Tech2's Avatar
Quote:
Not at the present time.
BMR Tech2 is offline   Reply With Quote
Old 02-06-2009, 09:27 AM   #4
BMR Tech2's Avatar
bump for 2/6
Old 02-06-2009, 07:29 PM   #5
The front cradle is pretty robust, but the "A Arms" don't need replacing.
This pic (stolen from Wretched) , shows the front Radius Rod and front lower control arm. They are pretty light-weight to begin with.
GeorgeInNePa is offline   Reply With Quote
Old 02-06-2009, 07:37 PM   #6
Firebirdfan's Avatar
G8s have a MacPherson Strut front-end?! WTF? I thought they had SLA front ends like F-bodies and vettes
Firebirdfan is offline   Reply With Quote
Old 05-20-2009, 11:40 PM   #7
2002_Z28_Six_Speed's Avatar
Quote:
I wish....
MacPherson can handle ok but nothing can control camber curve like double wish bone.
How much of a loss is it?
I don't know.
But I am sure MacPherson + IRS is better than Double Wish bone and live axle.
2002_Z28_Six_Speed is offline   Reply With Quote
Old 05-21-2009, 10:56 AM   #8
edmanet's Avatar
I have those trailing arms on my car. They work.
edmanet is offline   Reply With Quote
Old 05-22-2009, 10:20 AM   #9
Greenfire's Avatar
Nice.
Greenfire is offline   Reply With Quote
Old 05-22-2009, 12:49 PM   #10
Quote:
Can you give more information?
What did it change as far as what you couldn't do before?
How did it change the feel of the car?
Old 05-23-2009, 05:57 PM   #11
edmanet's Avatar
With tHe combination of the bmr trailing arms and the peddlers x bushings
I have no wheel hop. I also believe the car plants better.
Old 05-23-2009, 09:37 PM   #12
GRRRR8's Avatar
Some pics of them.
GRRRR8 is offline   Reply With Quote
Old 05-24-2009, 02:01 PM   #13
That is cool
I went to the track last night and I did have significant wheel hop any time i tried to put power to the wheels.
I was only able to land a 11 98 on 1000 without loosing complete traction. I tried....
Better tires and possibily these trailing arms could help
how do the trailing arms really help?
are we seeing an issue where the factory trailing arm is allowing the wheel to move back and forth in relation to the body under load?
also i will probably have to look into getting some new tires
thanks
Old 05-24-2009, 07:41 PM   #14
GRRRR8's Avatar
Stops the wheel hop. If you really want to hook, install Pedders rear subframe and diff bushings and the control arms.
Related Topics
Thread Thread Starter Forum Replies Last Post
BMR Launches New Product - G8 Rear Cradle Bushing Kit (BK003) BMR Suspension Pontiac G8 2008-09 & Chevrolet SS 2014+ 13 03-11-2010 07:35 PM
BMR Launches New Product - G8 Front Suspension Bushing Kit (BK012) BMR Suspension Pontiac G8 2008-09 & Chevrolet SS 2014+ 0 01-02-2010 01:34 PM
BMR Launches New Product - G8 Rear Suspension Bushing Kit (BK007) BMR Suspension New Products Showcase 0 11-20-2009 10:30 AM
BMR Fabrication Launches New Product - 2010 Camaro Trailing Arms (TCA026) BMR Suspension Gen 5 Camaro Suspension Tech 17 09-18-2009 05:21 PM
BMR Launches New Product - G8 Strut Tower Brace (STB012) BMR Suspension Pontiac G8 2008-09 & Chevrolet SS 2014+ 10 02-07-2009 01:40 AM
Tags
arm, arms, bmr, comp, control, fabrication, g8, gxp, lower, pontiac, press, product, release, trailing, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
