Dual pumps / custom fuel systems
Still working on the actual setup for this car (prototype pump kit is in hand), but it is very comparable to the multiple models of dual pump kits that I offer. They will support in excess of 1000rwhp.
This kit will use a modified stock fuel sender for ease of install & reliability.
Obviously I will not be posting pictures of the modified pump setup as I'm trying to protect my R&D expenses.
I'm planning to provide them with a complete wiring harness & also an optional fuel system, including lines, rails, regulator & filter.
Here is a picture of a typical fuel system.
I'm interested in this. Thinking of putting on a Procharger and have heard of several people running into pressure issues with the stock system. Even with a BAP some are seeing 10 PSI drops when demand starts to pick up.
STF Veteran
I have been looking into this application & would be glad to produce a kit for this car.
It looks as though it will require at minimum a separate filter, regulator & return line to make it functional.
I will offer a kit complete with fuel lines (-8 supply & -6 return), fuel rails, regulator, filter & all fittings.
Frankly, I forgot about this thread & have not checked it lately.
If anyone is ready to upgrade, please contact me at 724-322-8505 from 9:00am-11:00pm eastern time, including weekends. I'll be glad to work with you in geting you a setup good for 1000+rwhp. These will be compatible with forced induction, nitrous or normally aspirated engines.
Thanks for the interest.
