Front End / Steering Shake
Hello Everyone,
I have an 09 G8 GT with about 15,000 miles on it. I had a Charger R/T before this car... it was nice, but I love my GT. I wish it had a better exhaust note, but other then that I love everything about the car.
A few months ago I developed a shake in the steering wheel at speeds over 65 MPH. The tires have been rotated with each oil change, so it's not uneven wear. For the most recent oil change I decided to take the car to my dealer (Sun Auto Group in Wantaugh) and explained the problem. They told me that they would have a tech drive the car, but not at speeds in excess of 55MPH. I explained to them that I drive interstate often and the speed limits are higher. I was told that they could not risk the safety of the tech at speeds above our local limit. I offered to drive the car with the tech as a passanger and again was told that the dealership could not risk the safety of the tech. I spoke to the manager who gave me the same story. I kept my calm and asked that an alignment be done on the car and to have the tires rotated and balanced. I picked up the car that night and there was no change on the ride home. I called the dealer the next day and was told that there was nothing that could do because the tech had not experienced the issue that I was describing at legal speeds.
I need some help. As the miles have piled up the shake has gotten worse. The steering wheel twitches more than ever, you can see the head rests moving, and passangers have started to comment that they can feel the floor vibrating. This doesn't happen nearly as much at 55 MPH. I'm not being picky, I've had a C5 Corvette and a G35. I know the difference between road feel and a vibration. If it matters, I don't have the sport package. I have 18" wheels with all season tires. Has anyone had a similar problem with the front end? If not, can someone in NY recommend a different dealer that I can try? I'm pretty pissed off that the problem still exists after my $250 alignment and I'd rather not give Sun my business anymore.
I'd appreciate any help or feedback the board can provide.
-Tommy
-Tommy
I have the exact same problem. My car is a 2009 with 1500 miles on it. Mine doesn't vibrate as bad as you described but it does feel like the front wheels need to be balanced. I took the car to the dealership and tech said he could not reporduce my concern. So typical. They did say that the 6 cylinder models are notorious for this problem but they have not had any GT customers complain and I was the first. I'm going to go back and make them road force balance the tires.
They all pretty much have this issue, HUGE thread on g8board about it. My GT and GXP also has the same shake occasionally but it's not bad enough to hassle with it.
x2 on the road force balance. Had it done on my truck at 6k miles and they had to replace two tires cause they were not able to bring them into spec. I am starting to have my doubts on the qc of oem tires.
I just purchased a 09 GT used and they said they need to turn the rotors on it. Service manager is pretty cool and he said that GM was recommending to turn the rotors every 25,000 miles, under warranty of course.
i got the car back today, they only replace the passanger side and the shaking is about gone, and they ordered the driver side to replace also, so hopefully this get ride of the problem. the dealer said that they all have lower control problems
I hope it is not all...
I have over 6500 miles and drive at speeds well over 65 mph to work and back and no problems yet. I also have the 18 with all season.
I just solved my problem after a long battle with the dealership 3 1/2 months. My car came with 245/40R19 Potenza's RE050. Finally they gave me a new set (same exact tires, just NEW). You wouldn't believe it......like a brand new car! So I say keep complaining to the dealership, it was a bit of a stressful journey but it paid off. Good Luck!
there are a TON of GM bulletins about the shaking guys. i work at a GM dealership and they have traced it back to the driveshaft. the dealer must replace some other things first and make sure that everything is in spec but they will end up having to replace the driveshaft in most cases. ask your GM dealer to do some research on this because there is a bulletin explaining the whole thing and they will get payed to fix it so they shouldnt have a problem doing it. if you guys are having problems with your dealers PM me and i can get you the bulletin number.
