G8 GT Rear End Swap - Page 2 - LS1TECH
Pontiac G8 2008-09 & Chevrolet SS 2014+ LSX based RWD 4-door sedans
G8 GT Rear End Swap
Thread Tools Search this Thread
Old 11-01-2011, 07:32 PM   #21
Quote:
Originally Posted by priest01ss View Post
Were any modifications required? Did the stock drive shaft and axles mount up? What all did this entail other than just dropping the old diff out, installing the new diff and tuning the transmission? The more information you can give the better. I hate to ask stupid questions but I always like to err on the safe side before attempting a mod/swap. Thanks.
No additional mods required, it's really as simple as a swap and then tune. You could get 2 axel seals to be safe incase you damage the others on the swap, but that's it.
Rawyzf is offline   Reply With Quote
Old 11-02-2011, 06:06 PM   #22
As said earlier; no additional parts are needed but......it's an excellent time to change the cradle bushings while you have it torn apart.
After market bushings are much better than factory quality and help reduce wheel hop.
G8RAM is offline   Reply With Quote
Old 11-04-2011, 04:11 PM   #23
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
How bad of a hit does your mileage take?
1slow01Z71 is offline   Reply With Quote
Old 11-04-2011, 04:29 PM   #24
Quote:
Around 1mpg.
Old 11-09-2011, 10:35 PM   #25
Drumsbh's Avatar
Rawyzf, how about the PITA to tune in the new gears??? :-)
Drumsbh is offline   Reply With Quote
Old 11-24-2011, 10:10 AM   #26
Cool Tuning New Gears
OP HERE,
I've seen a lot of comments, on several forums that tuning new gears is difficult.
I mentioned that to my tuner and he looked at me like I had three heads!!!!
Using HPTuner, he completed the tune is less than 5 minutes and it was spot on.
I checked miles per hour with my GPS and it was perfect.
He had to enter the tire size, and new gear numbers. Computer automatically made 103 changes to my setup.
As usual it comes down to the knowledge of the tuner.
Good Luck!!!
Old 02-01-2012, 01:44 PM   #27
Quote:
Originally Posted by Rawyzf View Post
I've had the 3.45 Camaro Diff Swap in my G8 for about 4 months now. It's a great mod!
As for putting just 3.45 gears into a G8 Diff, that won't work. You need the whole Carrier/Pumpkin/Differential from a Camaro, whatever you wanna call it.
Just curious. I have a 2009 G8 GXP, just wondering if the 3.45 gears from the Camaro will work with my differencial or if I need to have the whole Carrier/Pumpkin/Differencial?
Racin4Ever is offline   Reply With Quote
Old 02-01-2012, 01:54 PM   #28
Quote:
Humm, I am not 100% sure on that. But I think you need the whole carrier.
Do you have the 3.70 or 3.27 gears in the GXP?
Old 02-01-2012, 04:23 PM   #29
I have the 3.27 gears in my GXP as it is an Auto.
Old 02-01-2012, 08:13 PM   #30
wreckwriter's Avatar
I started off with 2.90 of course, upgraded to 3.27 then upgraded again to 3.70 with a Harrup Truetrac. The 3.27 were great for the street but once I went to slicks I felt the 3.70s were a necessary change. Trans tune for new gears is simple, you just have to change the ratio and shift points. A decent tuner can do it real quickly.
wreckwriter is offline   Reply With Quote
Old 02-01-2012, 08:52 PM   #31
Devilish34's Avatar
no it will not fit.. your best bet is sell your diff and buy a camaro 3.45.. cheaper too
Devilish34 is offline   Reply With Quote
Old 02-02-2012, 06:47 AM   #32
why not just copy the shift tables from a 2010 camaro? (if you get the 3.27 gears)
Where did you get the camaro diff?
02NBMFormula is offline   Reply With Quote
Old 02-02-2012, 08:26 AM   #33
3.27 to 3.45 isnt much of a jump. But, if you decide to change internal gears within the pumpkin your options are a ton better with the 3.45 carrier. I don't know of anyone making gears for the G8 Diff, but there are a ton for the Camaro.
Old 02-02-2012, 02:29 PM   #34
Quote:
So what you are saying is the 3.45 gear set out of a Camaro will not fit in my G8 Pumpkin, but the whole Pumpkin from the Camaro will bolt up onto my G8?
Old 02-02-2012, 02:30 PM   #35
Correct
Old 02-02-2012, 03:36 PM   #36
Pumpkin swap is a helluva lot easier too, probably not much more money.
Old 02-07-2012, 03:31 PM   #37
I know this topis is for Gear Swaps, but just wondering if you guys had any input as to which would be a better intake? Vararam Ram Air Intake or K&N Cold Air Intake?
Old 02-07-2012, 06:43 PM   #38
Vararam for sure.
Old 02-08-2012, 10:29 AM   #39
Tainted's Avatar
They are all about the same as far as CAI. I saw Pat G's post on g8board about testing the vararam and it wasnt all that great. It made power, but was a tuning nightmare. Id go with a rotofab cai myself but my car came with the k&n already
Tainted is offline   Reply With Quote
Old 02-09-2012, 08:39 AM   #40
Swapping the diff is easy enough, if you have any questions just ask.
Ramjet and VCM are by far the best intakes for the G8... makes the Vararam look like some crap someone made in their garage.
SLOW SEDAN is online now   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
DIY Ford 8.8 into V1 Build thread 54inches Cadillac CTS-V 2004-2007 (Gen I) 602 02-22-2017 09:52 PM
MUST GO ***GREAT DEAL***** 2014 SS Camaro REAR END DIFFERENTIAL Iceman19 Parts Classifieds 12 11-16-2016 10:33 PM
Built 327 differential with housing Stephen McCann Gen 5 Camaro Drivetrain Tech 0 03-27-2016 03:39 AM
rear end leaking, not sure what area exactly? pics included. paradigmGT Gears & Axles 1 05-26-2015 10:11 PM
Difference between Z28 and SS diff rear housing S2KIWI Gen 5 Camaro Drivetrain Tech 7 05-11-2015 02:03 PM
Tags
09, diff, differential, end, g8, g8gt, gears, gt, light, people, pontiac, rear, stock, swap, tail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
