air induction problem.
my IAT sensor is telling me my intake temp is 140degrees. i have a AEM brute force intake which is supposedly make the inducted air cooler right? so the problem is that im losing 30rwhp when my car is at normal operating temperatures since it started warming up outside. anyone else have this problem or have a way to fix this problem? It is a 04 m6 goat if that helps anything. Thanks
i tested the battery and it was good. the whole thing is aluminum. it didnt do bad at all on the dyno back in april when it was nice and cold outside about the low 50's . now its in the lower 80's and its boggin out on me.
I agree. I have the same air intake and have no problems at all after 2 years of using it. Something is up, 30hp loss is almost like the car is in limp mode. Only other thing I could think of would be a new air filter.
go to caspers site and by a break out harness(mass air flow harness that allows you to put a different iat on the car), then buy a camaro iat and stick it in the front of you air filter, search on ls1gto for heat soak reduction kit
There are some timing tables that pull timing for IAT/ Coolant Temp/ etc that affect power once heat soaked.
Second what oshia86 said on GTO CAI not really being cold air.
Try to isolate the filter to the fender arear and not pull in any engine or radiator headt
Most of my posts and the info I find are on LS1GTO.com. That is the new Vararam though, and for less than $300, it is well worth the investment. Maryland speed and Veangence Racing both sell it. I am sure there are others also.
Did you install the intake and then get a dyno tune? It could be just the tune in the car that needs to be rechecked. No need to start jumping ahead and buying things for the car if it's a simple fix. Have your tuner check it out first.
yea my tuner said it was a heat soak issue.
