Pontiac GTO 2004-2006 The Modern Goat
gto/nitrous questions?
Old 06-28-2010, 06:41 AM
batboy's Avatar
I actually like to see more like 11.8 to 12.0 AFR on the spray. Now N/A yeah, 12.5-12.6 WOT. But he's right, the stock tune is a little rich to begin with, hower you should always check it with a wideband to see what your AFR is when spraying. With a wet shot, you can adjust the AFR by switching jets around.
Old 06-29-2010, 10:07 PM
ohshixgoat's Avatar
Originally Posted by 402GOAT
^^. You don't need to get a tune but you do need to check your air fuel ratio while spraying. You want it at around 12.5. I wouldn't go leaner on a stock motor. And you need a wide open throttle switch.
11.7 on spray. 12.5 is too lean
Old 06-29-2010, 10:28 PM
402GOAT's Avatar
if thats how you want yours thats fine. and it may be safer on a stock motor to be that rich. but when it come to tuning my tuner is excellent and has many hours of tuning under his belt. my engine is forged and he has mine tuned at exactly 12.5 to 1 because that is where it should be. on a non loaded dino it will read richer though so dont let that fool you.
13.7 on motor and 12.5 on spray
Old 06-30-2010, 09:54 AM
06GTOKID's Avatar
I was going to have a button setup with a arming switch. Is that a ok setup.
Old 06-30-2010, 01:38 PM
402GOAT's Avatar
I would set it up with a wide open throttle switch and an arming switch. That way you will only have to mess with one switch inside the car. Arm it then when your wide open you will spray.
Old 04-03-2016, 04:03 AM
Tunsi88's Avatar
Originally Posted by 06 6.0 GTO
I have a similiar question.
I have an 06 M6 and i plan on doing a 150 shot soon, and i will upgrade the plgs and fuel pump for safety as well. Im just waiting for my stock clutch to go out so that i can get a monster stage 3 and then spray.
But i plan on still running my stock 18s with 245 Falken Azenis, so i plan on having the shot activate in third gear.
Will i hook in third with that setup and also is there any way that with a more aggressive tire, say 17s and 275s, i will be able to hook in second?
275-40/17 Mickey Thompson ET Street's. I have them.... They are unbelievable. But i dont even spin in 1st anymore...
Quick Reply: gto/nitrous questions?
