how much to gain with just a simple gear change!! - LS1TECH
Pontiac GTO 2004-2006 The Modern Goat
Thread Tools Search this Thread
Old 11-23-2010, 08:56 PM   #1
Default how much to gain with just a simple gear change!!
how much u think to gain in the 1/4 mile from upgrading the gears to a 4.10's with a stock m6 with bolt ons ?
Fastdriver1992 is offline   Reply With Quote
Old 11-23-2010, 09:02 PM   #2
think the steepest they go is 3.90's, not much of a selection out there
sfuller442 is offline   Reply With Quote
Old 11-23-2010, 09:18 PM   #3
baalic's Avatar
@sfuller WTF ??? You can get 4.10s and alMost any other combo you want...?!
@ fastdriver. It depends if your getting traction, I would guess around .5 depending on your total setup..
baalic is offline   Reply With Quote
Old 11-23-2010, 09:31 PM   #4
for real? since when? i haven't had much luck finding gears for gto rear ends
Old 11-23-2010, 09:32 PM   #5
baalic's Avatar
All about money lol
Old 11-23-2010, 09:39 PM   #6
baalic's Avatar
Quote:
Originally Posted by baalic View Post
All about money lol
20 second search.
http://www.ls1gto.com/forums/showthread.php?t=5170
Old 11-23-2010, 09:53 PM   #7
I put 4.10's in my GTO back in the summer time along with new axles, stubs, clutch and driveshaft. Otherwise, I'm stock. The gears didn't even come CLOSE to living up to the hype that they've been given. The car definitely has more pick up and go in 4th, 5th and 6th gears, but I don't feel much of a difference at all in the first 3 gears.
Granted I never ran it at the track so i can't give you time differences, but for your car, you might see a few tenths depending on the cam you're running and its powerband.
theone61636 is offline   Reply With Quote
Old 11-23-2010, 09:57 PM   #8
you got me lol, still outta my price range
Old 11-24-2010, 10:20 AM   #9
Gears for the gto aint cheap.
Fastdriver, it's suspension.
danieloneil01 is offline   Reply With Quote
Old 11-25-2010, 08:24 PM   #10
yeah there rediculously expensive. its my friends goat 6 speed with a 230/236 .540/.540 110lsa and ls6 243 heads with bolt ons. he's hoping to run low 12's after the 4.10's
does this sound feasible?
Old 11-27-2010, 07:46 AM   #11
with bolt ons he should already be in the 12s .
im an auto with bolt ons ,and im in the mid 11s 11.60 with the stock gears
11.52 with the 3.91 gears.
66tomcat is offline   Reply With Quote
Old 11-27-2010, 10:16 PM   #12
but do u have the 6.0 or the 5.7? my friend has the 5.7
Old 11-27-2010, 10:48 PM   #13
ULTIMATEORANGESS's Avatar
i would think 11s with traction.
ULTIMATEORANGESS is offline   Reply With Quote
Old 11-28-2010, 01:16 AM   #14
LS2-TOY's Avatar
Quote:
I 2nd this. In a LS2 with cam, should be high 11's with a good 60' and traction.
LS2-TOY is offline   Reply With Quote
Old 11-29-2010, 02:01 PM   #15
svede1212's Avatar
I agree that with bolt ons he should already be in the 12s with a 5.7. With just headers I was 12.9x. That would mean the diver mod would be most beneficial. He'd probably lose tenths. I have 3.91s on my 5.7 now and gears made it harder to launch not easier. On the street they're fun on a roll but at the track traction is a problem
svede1212 is offline   Reply With Quote
Old 11-29-2010, 03:56 PM   #16
Quote:
car has pacesetter headers 1 3/4 long tubes not cats and loudmouth 2 mufflers. there is no restriction. looking at 4.10's with the mph he will be turning. i have an estimate. guessing at 400rwhp he should be going approximatly 115-119mph at best so here are the numbers and let me know what u think
Old 11-29-2010, 04:30 PM   #17
svede1212's Avatar
RPM-wise he'd be fine but I'll bet his 60 goes higher as well as his ET and he'll be fighting wheel hop. A4s with 400 RWHP and stock gears can do high 11s, very low 12s with only 110-111 traps. They're also getting 1.6 60s. He won't be running 115+ at 400 RWHP. My car runs like hell once it gets going but even trapping near 115 MPH I'm only getting 12.34 because of the 60 and I'm a decent driver. These cars don't launch like fBods. What's he trapping now and what are his 60s?
Old 11-29-2010, 04:38 PM   #18
Slo4's Avatar
Friend of mine went 11.85 @ 117 back in the day with the 3.91s, slicks and skinnies, and catless mids. They help quite a bit, but if you don't have good tires they will create a traction problem.
Slo4 is offline   Reply With Quote
Old 11-29-2010, 05:24 PM   #19
Quote:
he's got mickey thompsons, drag bags, and polyurithane bushings in the back. he ran the car wit street tires and couldnt hook up and only 60' 2.200 and ran 13.5 at 105 short shifting at 6000rpms
but since then he's added new injectors that he needed cause his were maxed out.
so drag radials
injectors
new gears
and shift at 6500rpms
Old 11-29-2010, 06:39 PM   #20
svede1212's Avatar
so drag radials
injectors
new gears
He maxed out his injectors? I didn't max mine out until quite a bit over 400 RWHP. I was also trapping 104-105 and 1.9x 60s bone stock with stock BFGs. The traps he's running don't sound right. IMHO gears are going to make his driving worse and I think they won't be a good bang for the buck on the strip. My 2
Related Topics
Thread Thread Starter Forum Replies Last Post
how much hp will i gain with cam and gears bball4robert1 Generation III Internal Engine 7 05-16-2012 01:26 PM
gains from tune in bolton/stock M6 car??? moge11 PCM Diagnostics & Tuning 0 01-04-2012 02:20 AM
le2 only heads hp gain? 9D4Z28 LT1-LT4 Modifications 54 08-05-2010 08:08 PM
gmmg hp gain? 9D4Z28 LT1-LT4 Modifications 9 09-10-2009 11:50 AM
hp gain with loudmouth??? lt1noob LT1-LT4 Modifications 6 04-17-2008 11:06 PM
Tags
2004, 308, 410, 456, change, changing, gain, gains, gear, gearing, gears, gto, pick, rear, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
