Radiator problems.....
OK so my younger brother has a 04 GTO and his radiator just started to leak from the top driver side....looks to be around the metal and plastic/ polymer part. Do you guys think it could be fixed or should he get a new one. Will a radiator of a F-body work on the GTO?
Thanks for any help.
i can help with this somewhat, IIRC, Griffen has a drop in replacement. I THINK. I could be wrong, but yes, the plastic tanks suck *** on our cars and do leak. Very common problem.
Like i said, im pretty sure there is a drop in unit. Ill double check that and let you know.
check out this thread, might help some.
http://www.ls1gto.com/forums/showthr...iffen+radiator
http://www.griffinrad.com/
if you go to there site and follow the tabs at the top with make model year etc. they list one for the goat
