Pontiac GTO 2004-2006 The Modern Goat
maintenence
Old 02-01-2011, 12:05 PM
Pillion88's Avatar
Default maintenence
Changed the oil on my 05. Put 5.5 quarts in like the manual said. Ran it didn't register on the dip stick. Added the other half quart let it run then cool a little and checked again nothing still. Against my better judgment I added another quart, only this time it registered low on the dip stick. Added one more and its in operating range. So a total of 8 quarts in my ls2. And everything seems to be copesetic. Anyone else have this issue?
Old 02-01-2011, 01:16 PM
FryZ71's Avatar
Including filter change, 6 qts. here.
Old 02-02-2011, 08:23 AM
Pillion88's Avatar
Correction I put 6 in to begin with manual says 6.5 with filter.
Old 02-02-2011, 09:43 PM
black00TA's Avatar
mine has always taken 6qts initially then after putting about 5 miles on it, it asks for another half quart.
Old 02-03-2011, 02:20 PM
Buzzmanb12's Avatar
Unless you have an aftermarket deep sump pan, that is a bit much.
