Pontiac GTO 2004-2006 The Modern Goat
traction control issue
Old 03-17-2011, 11:03 AM
blue0453's Avatar
Default traction control issue
When I start the car up the traction control is on like its suppose to be and I can switch it back and forth like it should. But as I put the car in gear it gos to traction off and I can not switch it back. Any ideas. Nick
Old 03-17-2011, 11:32 AM
time3777's Avatar
Check your maf sensor, it will cause the traction control to turn off.
Old 03-17-2011, 12:42 PM
blue0453's Avatar
Ok funny you say that because I just recently took the stock airbox out and put a cone filter on the oem intake tube. I took the maf off and cleaned with maf cleaner but no luck. So I disconnected the battery for a few to let the computer reset and see if that does anything. I also went ahead and put the factory air box back on.
Old 03-17-2011, 01:37 PM
time3777's Avatar
I run mine with a cone filter, check the wires,mine had a crack in a wire at the maf and I had to repair it.
Old 03-17-2011, 01:57 PM
RedfoxGTO's Avatar
Do you run customer tunes? I have a tuner and I did a little tweaking in it... came to found I did something wrong because I had the same issue, I reinstalled the tune and problem GONE
Old 03-17-2011, 02:14 PM
blue0453's Avatar
The car is bone stock minus the cone filter I had put on and hid headlights.
Old 03-17-2011, 02:17 PM
blue0453's Avatar
Well I reconnected the battery and no luck, and I have noticed that you dont even have to put the car in gear. You can just give it a little gas in neutral and the traction off indicator on the dash comes as soon as you do it. Hummm, maybe the maf is bad.Because it seems like soon as it picks up airflow in happens.
Old 03-17-2011, 03:26 PM
time3777's Avatar
Take it to autozone or some where they scan it for free, it will tell you what your problem is. good luck.
Old 03-17-2011, 03:38 PM
blue0453's Avatar
Yeah my buddy is gonna scan it with hp tuners, I will let yall no what it says.
Old 03-18-2011, 01:55 PM
Robofuzz's Avatar
It's a MAF sensor issue and/or a vacuum leak after the MAF.
Old 03-18-2011, 03:15 PM
impulsegoat's Avatar
Mine never did anything like this when my maf went bad but hopefully its an easy fix. Goodluck
Old 03-18-2011, 11:29 PM
jimmy2120's Avatar
my traction control was kinda acting up in a similar manner. when i got on it while driving or revved the car up it would cut it off. i took it to a mechanic shop they said alternator was bad, replaced it havent had a problem with TC since but now having other problems with car shutting off and idling problems. took it to another mechanic said my PCM is bad, another mechanic says i have a vacuum leak FML!!!!
Quick Reply: traction control issue
