Driveshaft Shop introduces a new rear Flange for the Stock Diff
Last week i had a thought about how to change the problem we were having with the threads on the rear plate. I had considered making it out of steel and still might but i came up with this idea. let me know what you guys think. The end is a 1350 End from a Driveshaft so you know its strong enough and we would supply it with a longer bolt and double nuts to ensure the bolts will not come loose ever !!!!!
We may also make it with a u-bolt yoke. this is only a prototype
only 1.8 lbs
what do you think ?
only 1.8 lbs
what do you think ?
holy ****! i was just looking into some kind of rear adapter plate for the rear diff because i want to use a 32 spline output shaft when i go back together with my trans and its gonna have a turbo 400 yoke, any pricing ideas yet? need a guinea pig?
I just might need someone to test, The aluminum end is for the guys that don't want to open the Diff up so its a easy bolt on job (i believe it will be 199.99)
If you running higher Hp we have this billet 4340 Rear Pinion flange set up also
this with the 1350 flange its 249.99
But then you could always go to the 9" if your really pushing power !!!!
Ehh I'll wait until i pop my factory diff for a second time. Lol but I'm very interested in the flanges, no sure which one I want to go with. I like the simplicity of the bolt on one you prototyped. What kind of tq/hp would you rate your new one at?
im already running you guy's driveshaft in my car. i would be intrested in testing it if possible and for sure upgrading mine to this style adapter. let me know what you guys can do for me. im sure i can do some good stress testing for ya
Are you having any trouble with the rear plate ? it seems we have had someone spreading a rumor that the threads are stripping out and centering on the pin with
the flange is not working. let me know please.
Frank
p.s. read this about plates VS yokes on our blog if your intrested
Frank
Frank
Frank
