Does the M6 GTO have CAGS? - LS1TECH
Pontiac GTO 2004-2006 The Modern Goat
Thread Tools Search this Thread
Old 02-23-2004, 06:24 PM   #1
emarkay's Avatar
Default Does the M6 GTO have CAGS?
Question:
Does the Pontiac GTO has skip shift solenoid fitted (CAGS) Does it have a skip shift lamp?
Thanks!
emarkay is offline   Reply With Quote
Old 02-23-2004, 06:42 PM   #2
Yes, and I don't know. My car is a month off - but the CAGS eliminator is sitting in the living room waiting...
DANSLS1GTO is offline   Reply With Quote
Old 02-24-2004, 01:49 AM   #3
Stormguy03's Avatar
I have a skip shift eliminator on the way for my goat. That skip shift crap is friggin annoying. Especially in traffic when you need to be going with the flow.
I see no purpose what so ever for a skip shift, accept to disable it!
Stormguy03 is offline   Reply With Quote
Old 02-24-2004, 07:06 AM   #4
Well, it most likely saved you $1000 on the purchase price of the vehicle. I figure the $25 for the skip shift beats the grand...
Old 02-24-2004, 10:32 AM   #5
redz_02's Avatar
he's right, it's on all the six speeds, even the viper. It improves city driving gas milage book wise, therefore it lowers taxes.
redz_02 is offline   Reply With Quote
Old 02-24-2004, 03:52 PM   #6
emarkay's Avatar
It's for the CAFE. No other reason than that.
So just for sure, it DOES have CAGS, and there IS a lamp in the cluster for it?
Old 02-24-2004, 11:31 PM   #7
yes there is.
cm_ls1 is offline   Reply With Quote
Old 02-21-2005, 04:45 AM   #8
I've been looking around... and I'm clueless... what's the CAGS?
Bubba_Goat is offline   Reply With Quote
Old 02-21-2005, 06:36 AM   #9
CSiJason's Avatar
1600 miles on my 05 and I have yet to get 'caught' by CAGS. Their is a little light on the dash that illuminates when it is going to send you to 4th instead of 2nd. When I see that, just keep accelerating in 1st a bit longer. The window of RPM, speed and throttle position that CAGS will function in is so small on the 05's you may never notice it.
CSiJason is offline   Reply With Quote
Old 02-21-2005, 08:02 AM   #10
It's like 16-19mph on the 04s I don't think they changed it.. I only got caught once or twice with it.. Spend 10 cents on a resistor to fix it.. (I programmed mine out - but that's not an option for you 05 guys yet)
Jfulcher is offline   Reply With Quote
Old 02-21-2005, 09:56 AM   #11
GTO Forum Director
CMNTMXR57's Avatar
CAGS = Computer Aided Gear Selection. Every M6 has it, including the GTO.
You get two messages/lights. One a "1>4" idiot light and if you catch it properly a gate layout in the DIC (Digital Info Center) in the center of your cluster with an animated 1 through 4 pictograph.
The CAGS eliminator solenoid from any T56 will work, or you could do it the same old Radio Shack way.
CMNTMXR57 is offline   Reply With Quote
Old 02-21-2005, 10:36 AM   #12
Programming is best as it removes the idiot light too..
Every GM V8 6 speed car has it.. If you have programming in your future just do the Radio Shack way until then.. Or deal with it - it hardly comes on.
Old 02-22-2005, 01:08 AM   #13
Hang on... you're in first and the car shifts irself into 4th??? WTH is with that? Can you not move the shifter from first (unless that moves by itself) into another gear? Also... I saw it mentioned it's from 16-19mph, well when I took the 05 M6 on a test torture, I never got close to that window. lol
Old 02-22-2005, 03:26 AM   #14
If you are in 1st, and inside the window a solenoid shuts off 2nd gear which is supposed to force you into 4th. Instead it tends to freak you out unless you were watching the dash, you end up fumbling with the gear shift which tends to be embarassing if you have a passenger..
Old 02-22-2005, 11:03 AM   #15
BlueSix's Avatar
CAGS does suck, but not enough for me to disable it. I just shift to third.
BlueSix is offline   Reply With Quote
Old 02-22-2005, 01:37 PM   #16
GTO Forum Director
CMNTMXR57's Avatar
Believe it or not, once you own one you'll find that it doesn't mean that you hammer it from every stop. There are times you pu$$y foot it out, CAGS enacts, pushing the shaft out (effectively blocking the gate for second) and since you're pulling in a down fashion, 4th is the next available gate.
It wasn't a passenger embarrasment that caused me to override it on my first M6 LS1 car, it was nearly getting t-boned because I was expecting to go to 2nd, instead routing me to 4th bogging the engine.
Old 02-22-2005, 02:22 PM   #17
BlueSix's Avatar
Quote:
I just make a mental notice of that and accelerate long enough in first in those situaions that CAGS won't engage.
In all honesty...i'm just too lazy to go buy the resistor and do it...
Old 03-07-2005, 01:01 AM   #18
SHAGGY's Avatar
Thats good info to know. Thanks for the heads up.
SHAGGY is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Cags jim9 Manual Transmission 6 06-13-2016 01:06 PM
!cags questions Chase22 Manual Transmission 3 12-06-2007 05:12 AM
Cags? Sgt. Spuds Manual Transmission 7 11-19-2005 10:18 PM
CAGS or no CAGS on '05's? Nightclaw Pontiac GTO 2004-2006 15 10-12-2005 11:34 AM
Tags
1st, 2005, 2006, 4th, cags, disable, disablign, dodge, engaging, forces, gear, gto, manual, moves, shift, skip, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
