Need wheel / tire size help for our GTO's
Ok, I don't have a lot of time to make a decision here. A good friend of mine has a set of tires he bought and he put them on his Z06 and didn't like the way they looked. He offered to sell them to me dirt cheap, and they are all BRAND NEW. But the problem is I have to buy new wheel's to fit the tires. Which isn't a big problem because I've been wanting new wheels anyways but didn't have the budget for wheels and tires. If these will fit, it would be possible.
Tires are 295/30/R18's. I believe he had them on an 18"x10" wheel.
I currently have 245/35/R18's on 18"x8" wheels.
Is there any way these tires will fit on our cars? If so what size wheel & offset would I need?
Finally I don't know if it matters but my car is an 04 model.
Hopefully you guys can help. Thanks.
And sticky 275 are plenty enough.
Anyway, what brand tires are those? You could fit them on a 9.5" wheel with high offset and possibly use a spacer if they hit the inner wall. But then you would have to do something to your suspension/fenders in order to keep them from rubbing.
You could make it happen sure, but you would need some body work and suspension.
