Pontiac GTO 2004-2006 The Modern Goat
04 GTO auto transmission help!!!!
Old 08-26-2011, 07:22 PM
cubezilla's Avatar
Question 04 GTO auto transmission help!!!!
Car belongs to my girlfriend and is completely stock w/78,000 miles and when leaving from a stop, the shifting is delayed from 1-2 and 2-3 and 3-4 gear, You have to mash the gas and go but get off the gas for it to shift into the next gear. Any suggestions , if I need a trans who should I buy from??? I have seen some totally rebuilt from EBay but not sure if that's the best option. Being her only means of transportation, the car cannot be down, I'll have to swap them out on a weekend.... Someone give me some info....
Is this some kind of shift sensor or is this thing about to tear up???
Old 08-26-2011, 07:57 PM
402GOAT's Avatar
Sounds like it's toast to me. I wouldn't go eBay for a trans. Just my opinion though. You could always check with a local gm dealer and get a certified rebuilt trans. Or go to the auto trans section on here and get one from a sponser.
Old 08-26-2011, 07:59 PM
402GOAT's Avatar
Oh I meant to add, check your fluid level and condition. If it looks really brown and smells burnt i'm sure it's done for.
Old 08-26-2011, 11:30 PM
batboy's Avatar
Yeah, check fluid level first. Otherwise, sounds like she needs a new trans. I would get one from Performabuilt (which is what I did).
Old 08-27-2011, 08:45 AM
cubezilla's Avatar
Actually the fluid had been flushed when she had it serviced, thought it was a good idea. And as of right now the fluid in it looks great, wish I could of seen the old fluid to help me determine the Problem...
Old 09-23-2011, 09:54 PM
One Bad Duramax's Avatar
aww crap that's what did it.. last time i did that to my truck , $1500 later new trans
Old 09-24-2011, 09:06 AM
massillongoat's Avatar
performa built give them a call
Old 09-26-2011, 07:06 AM
mark21742's Avatar
Id even try a new gasket, filter and fluid 1st, then if that doesn't fix it call Perfomablit transmissions
Quick Reply: 04 GTO auto transmission help!!!!
