Pontiac GTO 2004-2006 The Modern Goat
Dynoed the 06
Old 08-31-2011, 09:59 PM
95ztrey's Avatar
Default Dynoed the 06
Well dynoed my 06 spice red GTO this past weekend, very pleased with results.
Mods are
Pacesetter longtubes , custom 3 inch dumped exhaust i built, b&m shifter .
car is untuned , 97.6* weather 9% humidity DA was 6800 during pull if that matters. IATS reached 129* during pull ...... Vararam on the way along with getting a tune this weekend. hope for some more gains!! car has run a best here of 13.01 @ 107 1.97 60' 6700 DA
369rwhp/374rwtq
Old 09-01-2011, 12:20 AM
impulsegoat's Avatar
Those are really solid numbers with high iat temps and horrible DA's. The vararam should def help you out a lot. Good luck with the car bro.
Old 09-01-2011, 08:03 AM
svede1212's Avatar
After being on different dynos I don't put much into "numbers" other than a comparison of one mod to another on the same dyno. DAs shouldn't matter as they should be correcting for them provided they do it right. Now trap speeds and DA say a lot
Old 09-01-2011, 09:09 AM
95ztrey's Avatar
I hope to get 380 out of her with a tune and CAI!
Old 09-01-2011, 03:27 PM
ULTIMATEORANGESS's Avatar
i think youll get that easy.
Old 09-01-2011, 07:08 PM
96WS6guy's Avatar
Thing to remember about the Vararam, you'll see a moderate gain on the dyno, but when you're moving is when it really outperforms most of the rest.
Old 09-01-2011, 10:16 PM
svede1212's Avatar
If they dyno with fans on an open hood you won't see any gain moving. Ram air isn't a real thing. The best a CAI can do is not take away power with the hood closed. I've done a lot of testing with "scoops" much better and in a bettter location than the hood ones and altho it helped get cool air in made no more power.
Old 09-06-2011, 08:42 PM
danieloneil01's Avatar
You pulled a 13.01 with 369rwhp (untuned), 1.97 sixty with a DA of 6700' in an M6 no less? You sure that DA is correct?
Quick Reply: Dynoed the 06
